Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 05-12-2008, 09:17 AM
kaimanson's Avatar
kaimanson kaimanson is offline
Red face Cruise Control
Hi guys! i'm back, I having a problem with the cruise control in my 01 nissan sentra SE 2.0 (manual transmission). Sometimes it works perfectly but sometimes it doesn't hold the speed. I can turn on the cruise control with not problem always, but when I'm going to set the speed...after pressing the buttom a few times...it doesn't set it. But sometimes it does it perfectly....I don't know what is wrong with it. I was thiking, maybe a bad relay?...fuse?.
Thank for you help guys, everything else on the car is running good thanks God.
Old 05-12-2008, 07:48 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: Cruise Control
at what speed are you trying to turn it on at? It will only work on from a certain speed. Example, it will only work after 40mph not below. That is just an example. I am not sure of the function speed. I think it's around 35mph. GL..
Old 05-12-2008, 10:45 PM
kaimanson's Avatar
Re: Cruise Control
That's correct, I'm trying to set it up between the right speed. 50mph to 75mph with the same result. For ex. today it was running great but this last saturday I had the problem once again with the cruise control.
thanks for the help "Fixurnissan"
Old 05-13-2008, 04:54 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Cruise Control
well, a cruise control is a relay, fuse, switch, wiring, and "motor". i put it in quotes because i dont know what the hell it is. anyways. its run off of engine vacuum, and a leaking vacuum hose could be the culprit. or a leaking diaphragm inside the unit. that should point you in the right direction.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 05-14-2008, 01:06 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: Cruise Control
pull out the drawer that the fuse box is behind it. check the 'map' on that drawer for the fuse for the cruise control. if the fuse is good, then maybe you have a bad headlamp or taillamp bulb. when one of the rear taillamp bulbs went out, i couldnt use the cruise control when the lights were on. but with them off, i could. changed the bulb and its back to working.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 05-14-2008, 12:17 PM
kaimanson's Avatar
Re: Cruise Control
Thanks for all the help guys, I'm gonna check all the fuse and stuff.
have a nice day
Old 05-18-2008, 06:32 PM
kaimanson's Avatar
Re: Cruise Control
I couldn't find any fuse related to the cruise control. =( The problem I'm having that the "SET" light is not coming on and neither the speed is holding, just sometimes.
thanks guys!
Old 05-23-2008, 02:52 AM
Chiquae07's Avatar
Re: Cruise Control
thanks guys!
well, just start pulling out fuses one by one and see if any are broke. its a start. if they are broke, replace them.
there is infact a fuse for the cruse control. tomorrow, i'll take a pic of the map on that drawer, and show it to you with it circled from ms paint or something of that sort. iirc, its a blue 15 fuse.
Old 05-25-2008, 08:00 AM
kaimanson's Avatar
Re: Cruise Control
Thanks Chiquae07, Here are some pics of the problem. I have the repair manual in PDF that I bought on ebay, but luckily for me the "CRUISE CONTROL diagram" file is corrupted or damaged lol...so I can't see where everything is, by any chance does any one has that diagram?...I wanted to check the whole system using the diagram. Yesterday I went to the movies and on my way there the cruise control didn't work at all, after I got out of the movie theater I tried it on the highway..and it was working...
not working: http://www.chinonegrodesign.com/inte...ot-working.jpg
working: http://www.chinonegrodesign.com/inte...cs/working.jpg
Thanks Guys! have a nice memorial day weekend!
Old 05-26-2008, 11:31 AM
Chiquae07's Avatar
Re: Cruise Control
so your cruise control works during the night, but not the day? that doesnt make sense. i forgot what thread i did this in for the pic pf the fuse box. just looked and there wasnt a cruise control fuse like i thought. o well. you can have this repair manual for free here. its for the 01 nissan sentra all models :
http://www.phatg20.net/index.php?opt...ileinfo&id=191
its in EL 170-175 are the diagrams.
Old 05-26-2008, 07:07 PM
kaimanson's Avatar
Re: Cruise Control
Oh this is great, thanks a lot Chiquea07. It has everything about the cruise control.
Once again brother, thanks a lot for the manual. I'll keep u informed about the issue.
have a nice day.
