Old 05-12-2008, 12:18 AM
isklopz isklopz is offline
Lost need help
I broke a spark plug in a 96 Chevy Corsica and i guess my mistake was to try to drill it out. Now I have a hole tha is a little short and my next step is to drill larger and place fix a threadin it. Is there an easier way to correct my situation then to forcably trying to re thread it? Can I remove the block and how do I do that? Despreatly seeking advice isklopz. PLEASE NEED HELP!!! I MESSED UP
Old 05-12-2008, 08:09 AM
kirkwood158's Avatar
kirkwood158 kirkwood158 is offline
Re: Lost need help
get heli-coil kit for the size you need and try drilling with that as it will replace the same size threads you need for plugs but will drill a larger hole to get plug out and the coil will put threads back to same size . (ask at auto parts store take plugs with you) ONLY problem is metal shavings and you must get as much out of the cylinder as possible. suggest bringing cylinder that is effected to TDC first then drilling and vaccumimg out even if you have to buy some attachments and vac. at hardware store and I know lowes has a good attachment set for small opening that will fit a good size vac. check it out ....been there dun that
IF I JUST DID IT RIGHT THE FIRST TIME
Old 05-13-2008, 12:17 PM
chevylady15557 chevylady15557 is offline
Re: Lost need help
i am trying to find someone that can tell me how to get the rest of my steering colum off to get to the four bolts that hold it together to tighten them up
