Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-11-2008, 11:24 PM
jveik jveik is offline
over full oil
my friend who is really stupid when it comes to cars was driving in front of me and another friend in his late 70's truck and we noticed his left tailpipe was emitting a lot of bluish-white smoke. we had him pull over and it appeared that his oil level was terribly too high. when we changed the oil, we put in about 6.5 quarts including what filled the filter. He had only added oil since he bought it a year ago without even checking the dipstick, so we used the empty quarts to see how much oil was in there, and it was about 9.5 quarts plus whatever had spilled on the ground. When we made him stop earlier in the day, i checked his oil pressure guage and it was very low at idle and only improved to about 15 psi on the guage at any rpm level. after we changed the oil, it would hit about 30 after you let off the gas (it jumped momentarily like many chevy engines seem to do after letting off the gas). we also changed all the spark plugs on the left side that was burning all the oil. it was dark by this time and we couldn't tell if it was still smoking or not.
does anyone here know if that over-full condition would really mess something up, since we are sure that the crank was frothing up the oil?
is his oil pressure problem permanent, or can we possibly run some sea foam through it to clean it out? a friend of mine told me that the really crappy oil may have clogged up his oil pump or i suggested maybe the oil passages and a good cleaner may be needed. any ideas from you guys? by the way, it's a big block 454
Old 05-13-2008, 09:45 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: over full oil
did the old oil smell like anything at all other than oil ?
was it real thin and like water runny ?
i suspect something is bad wrong
ruptured fuel pump or something else bad
need more details/info here
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-14-2008, 10:20 PM
Re: over full oil
funny you should mention the fuel pump, since his is leaking like a sieve. i heard that too much oil would mess with stuff like the oil pan gasket and whatnot. the oil was not very viscous, but it didnt have any foreign matter or anything in it. I can tell he messed it up over time because he said it used to have 60 pounds of pressure on the guage and now it will only make it up to 15 or 20 on the guage no matter what rpm it is turning. when you let off the gas it spikes momentarily like many other vehicles i have noticed. when it spikes it might hit 30 pounds for a split second and jump back down to about 15. this kid really needs to stop smokin so much weed, since it makes him do stupid stuff like this
when you mention ruptured fuel pump, could it possibly have pumped fuel into the crankcase through the pushrod hole?
Old 05-14-2008, 11:59 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: over full oil
Yes.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
