Old 05-11-2008, 10:48 PM
teronvir teronvir is offline
tragedy
I was driving the other day and I slightly lost control. This resulted in me hitting a reflector sign and driving in and out of a ditch at about 55 mph. I think in the process I had a fairly rough impact with a hole. Now my right front tire is scraping the back side only when I turn right and making an atrocious noise. The tire has been pushed back. Help me out please?
Old 05-12-2008, 01:23 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: tragedy
Sounds like you bent the suspension, but some more details would be nice, and a photo would be very helpful.
Old 05-12-2008, 02:16 AM
72chevelleOhio 72chevelleOhio is offline
Re: tragedy
So your out with your buddies driving doing the "puff puff pass" and when you turned around to pass it you went in the ditch, hit a culvert, and now wondering what lie to tell your parents????
nevermind that was.....
Yeah a pic would be helpful...
Old 05-12-2008, 02:51 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: tragedy
No, man... you pass to your right so he wouldn't have had to turn around assuming someone was in the passenger seat, unless he turned around to take it from the rear seat passenger. And if they were playing "puff puff pass", they wouldn't have been going 55, more like idling in 3rd . Sounds more like drinking to me. Anyway, you're lucky you didn't flip it over. I went into a ditch still going about 70ish (I think, I don't remember for sure)and wound up on the roof.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-12-2008, 05:59 PM
inafogg inafogg is offline
Re: tragedy
yeah not sure what car u were driving but bent something....ss for sure gotta get underneath & have a look
Old 05-12-2008, 09:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: tragedy
The anonymity of the net is a great thing. We will not think any less of you if you fully admit that you lost control and had an accident, no "slightly" about it.
We really need to know the make, year and model of the vehicle. Many later model cars typically will bend the lower control arm before bending the frame or structure of the car. If the impact was hard enough, you may have numerous damaged components, including the tire, rim, steering knuckle, steering rack or linkage, strut or upper arm, etc,
Also some pics would help. However, IMO take it to a good alignment shop, have them do some measurements to determine what is bent and by how much.
Old 05-15-2008, 03:23 PM
maxwedge maxwedge is offline
A990 racer
Re: tragedy
Lotta wasted typing in this thread!!! LOL
Old 05-16-2008, 01:42 AM
Re: tragedy
"Post count: one up"
okay, two up for me.
well, since we don't have a picture yet, I would say his parents found out and beat his @$$. lol
Or...(for MagicRat)...."Slightly" beat his @$$...
Old 05-16-2008, 02:38 PM
J-Ri's Avatar
Re: tragedy
You can "slightly" do something... like the time I "slightly" rolled my car
Old 06-13-2008, 02:55 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: tragedy
Sorta like being a little bit pregnant
Old 06-13-2008, 03:18 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: tragedy
I "slightly" dented mine.
It'll polish out.
Seatbelts Saved My Life
Old 06-13-2008, 06:13 PM
Moppie's Avatar
Master Connector
Re: tragedy
It'll polish out.
That is some pretty radical Toe your running, how does it turn in?
Old 06-13-2008, 06:41 PM
Re: tragedy
Makes awesome left turns. Right, not so good.
Old 06-13-2008, 07:20 PM
Moppie's Avatar
Master Connector
Re: tragedy
So is it set up for Brooklands or Indy?
Old 06-13-2008, 10:03 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: tragedy
It would be the perfect set up for an oval! Just better hope you are turning left around that oval
