Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-11-2008, 10:47 PM
Zeppo416 Zeppo416 is offline
A/C blowing warm/Engine High temp
Well If this was one problem I had it figured out. But while sitting to have the car washed at an automatic washer yesterday I had a problem. I have a 2003 GC Laredo-4.0-55K Miles. The A/C starting blowing warm and at the same time the coolant temp went up to MAX. When I started to drive again everything returned to normal. Any ideas.
Old 05-12-2008, 05:34 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: A/C blowing warm/Engine High temp
You cooling fan is not turning on or you have a bad fan clutch. you should have electric fan tho - so your problem is with the fan not coming on.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 05-12-2008, 09:58 AM
Thank you. That gives me somewhere to start. But the circuit that controls that isn't on the fan is it?
Old 05-12-2008, 04:37 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
There are several threads about the temperature sensor replacement and how-to's, do a quick search and you'll find them.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-12-2008, 08:21 PM
Bob D. Bob D. is offline
A bad Temperature Sensor is a possible, but as dk indicated, the fan or Fan Relay is the usual suspect on '99-'04 Grands.
This thread should help.
http://www.automotiveforums.com/vbulletin/t746537.html
Old 05-13-2008, 10:41 PM
Thank you, for the information. I will see how this goes.
Old 05-14-2008, 01:38 PM
Bob D, you're right on....fan relay often the culprit.
Old 05-17-2008, 03:13 PM
Ok, I have the relay but haven't had a chance to replace it yet. But it happened again. Someone else was driving the jeep, came to a stop light, the temp shot up to 260, then once they started to drive the temp came down half way. But the A/C didn't get warm this time. They were right next to a shop so I told them to stop in and have it looked at real quick. oh boy oh boy. Besides the usual recommendations they said that the thermostate was sticking. I know that is a possiblitiy. But I was thinking the thermostat but for some reason I had in my head what happens when the thermostat sticks open. Any more info.
Old 05-17-2008, 10:03 PM
If the T-Stat is stuck open it will take a long time for the Temperature to get up to operating temp and most times this will be followed by a CHECK ENGINE light - which will tell you the engine was too cold for too long.
I would stick with the Fan, not coming on, being the culprit for now.
And there is no way for them to be sure the THERMOSTAT is sticking unless they removed it and checked it.
