97 4.3 firing order
hi i pulled my #1 plug got it up on the compression stroke pulled cap and the rotter is facing #4 opposite of the #1 is that right.
it runs good sitting but no power at all just a bog and just checking everything.put a new coil,cap,rotter,wires,plugs,fuel filter,ignition switch,. and my code reader only pulls up codes 300 305 306 missfires nothing else thanks for any help |
Re: 97 4.3 firing order
Passenger side, front of cap to rear: 2, 4, 6.
Driver side, front of cap to rear: 3, 1, 5. P0300 is random cylinder misfire. P0305 is a misfire on cylinder #5. P0306 is a misfire on cylinder #6. |
If the new flat top dist cap the firing order is marked on the cap.
To set the dist/or rotor. http://files.automotiveforums.com/ga...hp?photo=51302
