Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 05-11-2008, 03:13 PM
thegreekstallion thegreekstallion is offline
Exclamation How can I program my remote keyless entry?
I was wondering if any one had a link to the instructions to program a remote for the factory installed keyless entry for a 1995 Firebird Formula.
I have found some websites that make you pay for the instructions, but I'm sure they are somewhere for free and I definantly don't want to have to pay the dealer to do it....
Thanks
Old 03-31-2011, 05:01 PM
KENNY GUIDO KENNY GUIDO is offline
Re: How can I program my remote keyless entry?
1996-1997 Keyless Entry Programming
Programming procedure: Turn ignition switch to OFF position. Remove RADIO fuse 17 from fuse block. Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode. Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds. Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding. Any transmitter code that was previously programmed has been erased. Body Control Module is now programmed to remote control door lock transmitter. When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled. Ignition switch to OFF. Reinstall RADIO fuse 17 to fuse block.
Also if its listed for your year on ebay or if its from the same year/model. It will work. Good luck.
