cam question
Has anyone used a crane cams grind (powermax 2010) in a 267?
If so did you have detonation problems? and what compression ratio do you have? I am building a stock 267 with a .030 overboar which will raise the compression a little over the 8.2 stock. There seems to be some augument over what the max compression for that cam is. I have even heard it may be in the 7s. t.i.a. Billy |
Re: cam question
I've not built a 267, but I am using a more aggressive PowerMax grind in my 350 with 9:1 compression (PowerMax 2030), no problem. I've used the same cam grind in a 305 with 267 heads, no problems. Looking at the specs of that cam (your 2010), it looks fairly mild and should work well with that engine, even up to 9:1 compression.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
