Go Back   Automotive Forums Car Chat > Ford > Freestar
Old 05-11-2008, 10:47 AM
pdfbjf pdfbjf is offline
Bad Vibration when braking at high speed
My 2005 Freestar Vibrates terribly when braking from high speed. It is NOT the brake pads or rotor, feels like loose in front end, but no shimmy even at 85+MPH. Could it be a steering part or suspension part?
Old 05-11-2008, 01:03 PM
jdl jdl is offline
Re: Bad Vibration when braking at high speed
I can't say about your y/m. On older, different makes and models, I've seen the piston freeze-up in the brake caliper, cause a terrible shudder, when you step on the brake. You might check for ABS codes, see if it shows anything.
Old 05-11-2008, 06:48 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
These actually had a known issue of brake harshness caused by the rear brakes. Ford made an updated pad and rotors were to be turned if not too rusty.
