Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-11-2008, 02:44 AM
CapriceBoy214 CapriceBoy214 is offline
Help!!!!!!!!
Ok, its almost summer and its hot down here in Texas. Well my A/C dont work. Which i can get fixed but I have a problem. It seems like my blower is always on. Heat comers from the airways under the ash tray and it gets really hot when i'm on the freeway doing speeds above 50mph. Can someone help out with this..Its very miserable..
Old 05-11-2008, 08:37 AM
Blue Bowtie's Avatar
Registered Offender
Re: Help!!!!!!!!
What year is the vehicle?
Old 05-11-2008, 10:49 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Help!!!!!!!!
His profile says it's an '89.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-11-2008, 12:19 PM
Re: Help!!!!!!!!
1989
Old 05-11-2008, 12:29 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Help!!!!!!!!
Check out the operation of the heater control valve (it's on the heater hoses, the supply hose, near the heater core at the firewall - has a vacuum line coming off it) and make sure it's closed unless the heater is on. Also, check to make sure the heater door closes under the dash. I would check the supply of vacuum to the system (beginning with the orb-shaped reservoir under the hood on the evap housing) and make sure that all of the vacuum diaphragms are working and that the heater control (on the dash) is also functional.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-11-2008, 12:38 PM
Re: Help!!!!!!!!
Well, once before I had my A/C working and when I took it to the shop, the problem was a wire hanging loose under my dash. That yellow wire has came loose again but I dont see where it goes. Its a couple of wires not connected to anything including my cigerette lighter. I CANT CHARGE MY CELL PHONE !!!!
My Bright Lights nor my windshield wiper switch works. My Electrical System is really not in good shape.
