Old 05-11-2008, 12:00 AM
W00dy W00dy is offline
Hard to start & no power
Today when I went to leave for work my 94 metro didn't want to start.
After trying 3 or 4 times it started ran rough for 10 to 15 seconds and died.
I restarted it and it seamed ok until tried to leave for work it would stall out & had no power so I left it parked.
When I got home from work I tried it again after I got it started the idle was somewhat low for about 10 seconds then normal for 10 seconds it did this for a few minutes then it ran ok for 3 to 4 minuets so I was able to put the car back in my driveway
I checked the timing and looked for vacuum leaks I also looked at the fuel Injector and I couldn't tell if that was ok or not it looked kind of drippy to me.
I replaced the fuel tank, pump, strainer & filter about a month ago so I think the pump & filter should be good.
Does anyone know what the problem might be?
(1.0L, 5SPD)
Thanks,
W00dy
Old 05-11-2008, 09:54 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Hard to start & no power
You did not mention whether you checked spark or not. I would check the plugs and remove the distributor cap and inspect the rotor. While the cap is off, crank it over and see if it's turning.
Old 05-12-2008, 09:12 PM
Ok it's got spark the rotor turns when I crank it over.
I replaced the distributor cap, rotor, plugs & wires.
I checked the fuel pressure and I'm 7 to 10 psi with the engine running or not so
I think I will remove the tank and recheck.
Thanks,
W00dy
Old 05-19-2008, 01:58 PM
91Caprice9c1 91Caprice9c1 is offline
No. First block off the return line with a pair of locking pliers and recheck. This may isolate a bad fuel pressure regulator. If pressure stays low, it may be a restriction in the feed line or filter, or a bad fuel pump.
-MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car
1993 Geo Metro - Accident
1991 Caprice 9c1 - Destroyed
