Old 05-10-2008, 09:16 PM
quackmandude quackmandude is offline
ac on, engine overheats...i think
ok i no the compresser pulls juice from the crankshaft, but should the engine temp go up a tad?? cuz if im on the highway for like 20 min with the ac on the temp on the stock gauge goes up i say 2-3 lines, and i get scared and turn it off. is this normal??? i wanna get a bigger raditator just to be sure, maybe a lighterpulley from 3sx to lighten the load on the crank. but is this normal, shouldnt the engine maintain the temp?
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 05-11-2008, 06:59 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: ac on, engine overheats...i think
My VR4 does this, my '94 SL does not. A couple lines I wouldn't worry about. If it's a line or two below hot, then I would worry. Have you ever had your coolant flushed? How old is your water pump?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 05-11-2008, 12:02 PM
the water pumps only like 2 years onld and everything was flushed then
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 05-12-2008, 09:26 PM
Hotshot8792 Hotshot8792 is offline
make sure your driver's side fan comes on whenever you turn on your a/c. If it does come on, then just watch the gauge for a little bit. Let it go up in temperature a couple of tick marks, as long as it doesn't go up to the top and stay up there, you'll be fine.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 05-13-2008, 11:09 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
+1 for checking the fan.
Old 05-26-2008, 07:03 PM
ok i went road trippin this weekend and i thought itll be a good idea to cgeck out the ac problem on the highway, nw i no its the radiator. when i drive at night, the engine temp doesnt go up at all, but in the heat of the day, it wen up to the upper quarter of the gauge. it has to be the air cominging in, so therefor if i get a better radiator it should ccol the air further and it shouldnt matter how hot it is out side...agree???
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 05-26-2008, 10:42 PM
Polygon's Avatar
The Red Baron
No.
When you're in motion the air moves over the fins cooling the coolant as it passes through the radiator. The fans do that job when the car is stopped or in stop and go traffic. You still need to check the fans. If they aren't coming on then it won't matter what radiator you get.
Old 05-27-2008, 12:17 AM
they r
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 05-27-2008, 11:14 AM
I would try a flush before anything else. I usually flush once a year. But really as long as its not pegged at the top of the gauge, you're not in danger.
Old 05-27-2008, 05:52 PM
yea maybe a flush is all i need... but buying the 3sx radiator isnt a bad isea right? it should help it out regardless
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
