Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-10-2008, 10:31 AM
Maine j Maine j is offline
Unhappy fender differences
I replaced my drivers side fender on my 85 chevy caprice coupe with a fender from a four door 88-90 caprice, Not sure exactly what year, Now im not sure if its a hinge difference from 85-90 or a difference in the fenders if there is any thats causing this gap between the two. It looks as if that side is too high or something any ideas will be greatly appreciated.
Old 05-10-2008, 07:20 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: fender differences
That's what shims are for. There might be minor differences from one car to another, but generally all '80 to '90 Chevrolet B-bodies interchange fenders.
The only difference you might encounter have to do with curb lights.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-11-2008, 12:53 PM
mike561 mike561 is offline
For future reference too, all box caprice rear and front bumpers are the same sizes too right?
2006 Chevy Cobalt LS
Old 05-11-2008, 02:34 PM
silicon212's Avatar
Confoundingly Lucid
The '80 to '90 ones are.
Old 05-11-2008, 03:58 PM
Maybe i didnt explain as clearly as i should have, But the hood is up higher where the hinge attaches to it on the drivers side only, On the passenger side its all original everything and its fine. So i was wondering if because i used the hinge off the other car if that could be the problem. And was there a difference in hinges 85-90.
Old 05-11-2008, 05:40 PM
silicon212's Avatar
Confoundingly Lucid
No, the fenders are the same and the hinges are the same. The problem you are encountering most likely has to do with shimming. Try adding or removing shims, also the hinge itself is adjustable so you might want to try that.
Old 05-13-2008, 09:54 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
80 to 90 are all the same
you need to shim and adjust it
its not fun often
you will need an assistant and some careful planning and physics type of thinking to get it right
and shims, plus or minus at different locations
remember that shims also go in the top rear of the fender to raise or lower it to match the hood and body lines at the door, at the big flat weird shaped bolt that threads down into the cowl of the car main tub body at the firewall
you cna also shim the fender up at the rad support end by shimming betweent he top side of the support and the underneath side of the fender
same concept as at the cowl firewall main vertical adjustment bolt
so..
i have removed billions of fenders from various years makes models of GM cars, including the 85 elky ss we just are now finishing up fully restoring that we started in august 07
we removed the doors and entire front clip we disassembled, i did most of that work, it is all painted and reinstalled and shimmed adjusted back to nicer than it was originally, by far
it took tweaking and hole enlarging and egging and so forth
you have to do what you gotta do
the factory did the same when needed
modifications
stampings were not perfect even when brand new off the sheetmetal parts presses
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-19-2008, 08:49 AM
Thanks alot, But how would i adjust the hinge? Because that seems to be the problem, The fender seems to be in the right place.
