Old 05-09-2008, 11:56 PM
farixrc farixrc is offline
99 metro uneasy on highway
Just bought the car. It is a 99 1.3 with an auto tranny. Has new tires on it also, but at highway speeds it feels a little bit uneay. Like I am driving in a wind storm. Is this common with these small cars or is there something that I can look to for fixing this problem? Thanks a lot in advance.
Old 05-10-2008, 03:20 AM
91Caprice9c1 91Caprice9c1 is offline
Re: 99 metro uneasy on highway
If you have P155 width tires on there, you might consider going to P175. Also check your shocks and have the car aligned.
Welcome to the forum!
-MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car
1993 Geo Metro - Accident
1991 Caprice 9c1 - Destroyed
Old 05-10-2008, 06:42 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
There are many things it could be, mostly worn out suspension or steering components. Take it to a good alignment shop and tell them it feels unstable, they'll check everything before doing the alignment.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 05-10-2008, 09:36 AM
spy1309 spy1309 is offline
Now depends at what speeds it feels uneasy, if you feel that at over 65 mph it is normal, the car sits preatty tall while the car does not have a wide stance, plus alot of air goes under the car at that speed creating a small lifting effect, and don't foget that the car does not weight to much.
Old 05-11-2008, 09:36 AM
idmetro idmetro is offline
Start with the easy stuff first: Check tire pressure, is it at spec? Are all the tires evenly inflated? Check tire sizes/types - you and I might not mix and match but I've bought cars where people did and had them behave slightly strange until I got things matched up. Hopefully it will be something simple!
Old 05-11-2008, 10:56 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Then check and see if the rear swaybar mount is broken and inspect the front of the car for rusted frame areas where the steering rods go through.
Old 05-11-2008, 01:32 PM
Thanks a lot for all of the replies. I will definatly start checking those things out. Thanks again.
Jesse
Old 11-27-2020, 09:16 AM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Correct TP(That's TIRE PRESSURE not toilet paper!) for all 1999 Metros is 32psi cold, front and rear.
