Old 05-09-2008, 10:18 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
new car woes... :( help!
1999 Acura integra LS 1.8L DOCH NON turbo (for now). 108k miles clean as shit! good compression across the board at 200 psi warm. new plugs, fuel filter, cap, rotor. At a red line shift when i want that extra passing power it blows smoke when i shift. i have lost a good amount of oil due to this i think. any opinions on where to start. i plan on: timing belt, water pump, tensioner, idler pulley, valve seals. starts up with no smoke, drive it like a normal person and doesnt smoke. only high RPM shifts i get a shit out the back pipe. yes i know to fix the problem drive it like a normal human being. no. it shouldnt happen when i drive it like that. my roomate has the same exact car and with 150k and his runs redline all day long no problems. any suggestions we'll go from there. no flamming.
Old 05-10-2008, 09:16 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: new car woes... :( help!
awesome car! always wanted to get me one of them teggys... my dsm blows black smoke at high RPM during WOT, but thats because i have a small boost leak... i already know where it is, i just havent gotten time to fix it... check for a vac leak on the teggy! that is not going to explain the disappearing oil, but under wot at high RPM smoke sounds very much like a vac leak to me, unless its blue smoke...
for nice car!
Old 05-10-2008, 09:19 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Its blue smoke if hes losing oil.
Nice car though, always been a fan of those model tegs.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-10-2008, 10:45 AM
Black99GST's Avatar
no, lol its blue smoke if he's BURNING oil
Old 05-10-2008, 11:03 AM
Killa's Avatar
Killa Killa is offline
Very clean looking car, yes start with all the thing that you list, I would do the same if I own a import. Timing belt is very important, make sure u get all the timing part from acura dealer.
About the smoke, my friend had exactly same thing when he race, what oil weight are you using ? my friend switch from dino oil to full mobil 1 and the problem go away, I dont know that would help your problem but that my
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-10-2008, 01:31 PM
Killa's Avatar
note : I just call him few min ago, and he say he been use diesels oils, to help reduce smoke at woot and less on consumption but I think using diesels on a import small engine is kinda over kill. But that what he told me.
GM FOR LIFE !!
95 camaro lt1
Old 05-10-2008, 02:04 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Nice, I always did like that style Integra. Cant go wrong with a B18 either, as far as Honda motors go.
As for your smoke probem, what color is it? I cant really see you having an RPM dependant oil burning problem, especially with good compression like that. If you were infact burning oil it would be from the valve seals. My guess is you are just going rich and pooping black smoke, in which case I'm not sure what the problem is other than (obviously) you are getting too much fuel.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-10-2008, 02:17 PM
Burning oil is a way of losing oil.
Caleb
vanilla gorilla
Old 05-10-2008, 05:18 PM
EDMUND65's Avatar
its white with a tint of blue smoke... only happens in high rpms
Old 05-10-2008, 09:16 PM
Thor06's Avatar
Jizzed In My Pants
Oooh, shit. Popped head gasket? I'd imagine coolant system and oil system pressures would be especially high in the upper RPM's maybe you just have a pin prick hole or two in it. Is there oil in the coolant or coolant in the oil? Are you actually losing any of either fluid?
Old 05-11-2008, 08:28 AM
EDMUND65's Avatar
losing oil like a mofo and its not leaking out ont he ground... the pan is wet but no dripage. so im going to take care of all that stuff you say while i have the cams out i shoudl just do the damn head gasket?
