Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-09-2008, 10:54 PM
armallard armallard is offline
Turn signal bulb 02' buick regal
How do i get to the bulb on a 02 buick regal its the front right...don't see anyway to get to it help please
Old 05-10-2008, 12:44 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Turn signal bulb 02' buick regal
Very simple. Remove the headlamp assembly and pull forward. On the back side of the headlamp assembly are two plastic spade type retainers/clips. Just pull up on the two retainers and the headlamp will release. Remove the rubber protective cover and then twist lamp socket to replace the bulb.
Timeslip 08/12/06
AF Community Guidelines
Old 05-11-2008, 09:22 PM
I don't see the clips you are referring to.....if i'm looking over at the back of the assembly where should they be?
Old 05-11-2008, 09:38 PM
BNaylor's Avatar
See pic below.
Timeslip 08/12/06
Old 05-11-2008, 11:18 PM
Thumbs up Re: Turn signal bulb 02' buick regal
Thank you....... worked like charm.... just couldn't see where it released from until your pic... again appreciate help.
Armallard
