Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-09-2008, 06:08 PM
bigbear514 bigbear514 is offline
oil leak
Hi I have a 98 base prelude with 149000 kms and have two oil leaks under the engine around two inches apart. I recently changed the oil pressure switch as that was leaking about a month ago . Where do you think the new leaks are comming from ? Any help would be appreciated .
Old 05-09-2008, 10:52 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: oil leak
Check the plug, make sure nothing is stripped. Jack it up and look around the oil pan gasget as well. And it MIGHT be your PCV valve. Try replacing that, because when I had a leak in my 4g, I replaced the PCV valve and it stopped.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 06-25-2008, 06:06 PM
joellthomas joellthomas is offline
Re: oil leak
The oil cooler (located under the oil filter) o-ring could be the leak. Hard to locate this leak.
Old 06-26-2008, 11:58 PM
Re: oil leak
Then again it might be as simple as just replacing your whole oil pan gasget. Make sure that your filter is cranked down, too.
Me: No you idiot.
Me: FAIL
