Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-09-2008, 06:08 PM
Kawazar Kawazar is offline
Location of orifice tube
Can anyone tell me where the orifice tube is located in the front on a 94 Sub? It looks like it light be behind the right headlight.
Old 05-09-2008, 09:05 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Location of orifice tube
If you have front air only- it is behind the passenger side turn signal- access by removing the lens----if it is front and rear air- it is just beyond the "Y" split on the liquid line running toward the front evap along the passenger side frame rail-- look for the dimples and the OT connection....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-10-2008, 03:09 PM
odojak odojak is offline
true
Old 05-10-2008, 05:14 PM
I found the Y connection. After it branches off to the 2 lines, one line has a threaded connection. Is the tube located in this connection?
Old 05-10-2008, 08:27 PM
brcidd's Avatar
Bingo.............
'99 GMC Yukon
Old 05-11-2008, 06:32 PM
I have another problem, A/C related but not the orifice tube. I purchased a rebuilt compressor today. The compressor only had one electrical connection on it. My compressor has 2, one behind the pulley and one on the back. I checked 3 stores (Autozone, Advanced and NAPA) and they only carry the compressors with the connector behind the pulley. They can't find one with the connector on the back. What is that connector for anyway?
Old 05-11-2008, 06:43 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
It is a pressure switch.
Look on the back of the compressers they have and see if it has a removeable plug in the back pressure switch hole.
If so you can install your old switch in it.
Also check the oil in the new compresser.
Some come with a full 10 oz. charge.
If so drain it out and add the proper amount and kind of oil.
The Murry and 4 season rebuilt compressers are junk.
Go for a brand new compresser.
MT
MT
Old 05-11-2008, 08:10 PM
I had thought about just swapping that switch but I thought maybe the rebuilt compressor would not have something installed inside if it wasn't already equipped with the switch. Also, I tried to remove mine and it won't budge.
Old 05-12-2008, 08:03 AM
MT-2500's Avatar
AF - Advisor
If it is the right compresser it will have a switch in it or a removable plug so you san install a new switch or your old one.
MT
MT
