Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-09-2008, 05:30 PM
lumberjak1984 lumberjak1984 is offline
Another post
I disconnected the battery to see if the check engine light would go off, cause i was fixing a air induction hose. Simple thing...no big deal. Put the positive cable back on and myy driver side headlight wont work. replaced the bulb with the other bulb. no good! but then it worked for a few seconds, then stopped. i checked all the fuses by the battery and there all good maybe theres a shortsomewhere??
Old 05-09-2008, 09:23 PM
gcwimmer gcwimmer is offline
Re: Another post
The head lamp fuse is in the front passengers kick panel.
Left front high #11 & #25 low.
Old 05-09-2008, 11:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Another post
Sounds more like a loose connection or broken wire than a short somewhere. A short would blow the fuse. If yours works sporatically, it's not a short.
-Rod
Old 06-29-2008, 03:56 PM
Re: Another post
thank you i didnt know there was a fuse box there. i think it is actually the bulb that blew
