Old 05-09-2008, 09:09 AM
b19980610 b19980610 is offline
2000 Intrigue - Turn Signal Problem
2000 3.5. When putting on turn signal, BOTH lights (left and right) flash, altho the other side is much fainter. So, when I put on Left turn signal it all 3 lights (dashboard, front, and back) flash normally, but also the RIGHT side also flashes (all 3 lights, only much fainter) Likewise is true when I put on Right turn signal (left ones flash, altho much fainter.)
I had replaced the Emergency Flasher switch two years ago, when turn signals didn't work sometimes (normal problem with these cars.)
So, I figured it must be that, so I replaced the Emergency Flasher switch again, but that did not fix the problem.
Anyone got any ideas? Thanks in advance.
Old 05-09-2008, 08:07 PM
harmankardon35 harmankardon35 is offline
Re: 2000 Intrigue - Turn Signal Problem
wow, yeah my first guess would be the multiswitch in the steering column...if thats been replaced then id be looking at the relays.
Old 05-10-2008, 05:00 AM
I fixed it. It was a short in an add-on plug for a trailer hitch that the previous owner put on. I just cut the wires to this add-on plug, where
it tapped in to the wiring harness to the taillights. Lucky guess on my part, since I don't know too much.
I really appreciate your reply. This forum has saved me a lot of money since I have all the same problems that everyone else has with this quirky car.
Old 05-10-2008, 07:20 PM
oh i know, its a short in your trailor hitch wiring!
damn, you beat me to it!
Old 06-26-2008, 11:22 AM
musiclover7019 musiclover7019 is offline
Can either of you guys tell me what the part number is for the emergency flasher switch? My turn signals have been wacky for a few months and everytime I try to get it replaced it's nearly $300!
