Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-08-2008, 09:58 AM
dsettlemoir dsettlemoir is offline
Can't read ECU code
I can't get a code reader to connect to the ECM plug under the dash. I have been to 4 different auto parts stores. The code readers keep saying no connection.
I checked the ECM fuse under the hood in the fuse box which is located right over the battery. I replaced the fuse with another one to make sure. Still nothing.
Am I missing a fuse or something else? I didnt' see anything related to the ECM in the fuse box located at the passenger side door. . There is a PCM fuse but I think that has more to do with the transmission.
By the way, I just replaced the Fuel Pressure Regulator. The van runs much better but I think there is still something going on with a sensor. The Service Engine Light is still on. I've tried resettign the ECM by disconnecting the battery for a few minutes.
I'd like to check the codes but can't do to problem just described.
Old 05-08-2008, 10:34 AM
meggabad meggabad is offline
Re: Can't read ECU code
Year of vehicle?
Old 05-09-2008, 03:15 AM
rockwood84 rockwood84 is offline
check the tps sensor and clean the iac right above the tps .autozone scanned mine try them
Old 05-12-2008, 03:09 PM
Can't read ECU codes 98 Venture
I have taken my van to 4 different auto parts stores. Each handheld machine will not recognize it is connected to the ECU plug under the dash.
I have checked the fuses. Any ideas?
Old 05-12-2008, 03:17 PM
Sorry. 98 Chevy Venture.
