Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-08-2008, 07:48 AM
nailer013 nailer013 is offline
Po455 & P1680 codes
On my 04 Trailblazer it 1st had a code of P0455 which I cleared then the
next day it went to the reduced power mode. I stopped it shut it off then
restarted it. It ran fine on the way home . I checked the code it was the
P1680. It has a the noisey air pump under the drivers seat.
Any ideas where to start?
Old 05-08-2008, 03:59 PM
maxwedge maxwedge is offline
A990 racer
Re: Po455 & P1680 codes
Welcome to AF Check this link for code definitions.http://service.gm.com/gmspo/mode6/pd.../2002file2.pdf
Old 05-09-2008, 01:26 PM
wardak33 wardak33 is offline
it looks like an issue with the pcm...try disconnecting the battery for about half an hour and see if that helps...its worth a try
2002 Oldsmobile Bravada AWD w/ SmartTrak
1999 Mitsubishi Galant 2.4L I4
Old 05-09-2008, 04:07 PM
A990 racer
Actually 1680 points to the TPS or wiring to it or the stepper motor, 455 is the vent solenoid or circuitry.
Old 02-16-2009, 01:06 PM
04trailblazer 04trailblazer is offline
my car just got this 1680 code. GM issued a message saying that you need to reprogram the PCM when you see this and it cost me 113 at the dealer to do this. and it took the day to do. but afterwards my car was running a lot cleaner and shifted much better.
Old 02-17-2009, 03:55 PM
A990 racer
Good info,but look at the dates before posting, this is too old, thanks.
Closed Thread
