Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-08-2008, 01:04 AM
jstylz352 jstylz352 is offline
my 96 eclipse gst wont start
i just bought this car and replaced the starter. i have a 96 eclipse gst and it wont start.. replaced the starter and all i hear is the winding of the starter. i can pop the clutch and it will start but cant turnover the key and start. what possibly could it be?? maybe the flyweel??
Old 05-08-2008, 08:45 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: my 96 eclipse gst wont start
It could be the flywheel, I would pull the starter off and inspect the flywheel. Turn the motor by hand and look at all the teeth. If the flywheel is fine then the starter is not kicking out and engaging with the flyhwheel.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-08-2008, 09:20 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Did it not start before you replaced the starter? My brothers truck did the same thing with a new starter from Autozone. Turned out to bad alternator right out of the box. Just spun, but didn't crank.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-08-2008, 12:29 PM
yea i just got the car and it didnt have a starter in it before.. i had to pop the clutch. but there were no teeth on the flywheel. so i guess im gonna get a new clutch and flywheel. go on ebay and get a ktd stage 3 clutch and flywheel. if it doesnt start then what do u think it could be??? but also u dont have to have a certain kind of flywheel do u?? just any kind but a lightweight
Old 05-08-2008, 03:58 PM
Holset powered 420a
No teeth on the flywheel?? Did you expect it to start with a new starter with a broken flywheel?? Your clutch is fine just replace the flywheel. Unless you want to do the whole thing while your in there. Also a stage 3 clutch is way overkill for what you will be doing with the car. Unless you have some high hp goals that you plan to hit soon.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-09-2008, 12:55 AM
it didnt have a starter when i bought it.. so when i put in the starter i saw that there wasnt any teeth on the flywheel. so a stage 3 clutch is to much.. never new that. so i should go with a stage 2. ok i got a another question. might also be the flywheel also.. but sometimes when i floor it.. it puts and then gets up and go. like it sounds like there is no gas getting through or something like that.. im not real sure. like u floor it and it takes a minute to get up and go.. like wanting to stall out or somethin
Old 05-10-2008, 12:33 AM
Holset powered 420a
Try to do a boost leak test, that might be part of your problem. Also post some links of some clutches that you are looking at and we can tell you whether or not it would be overkill for you.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-10-2008, 02:28 AM
alright so if it is still acting up when i get the flywheel i will do that. hopefully its just the flywheel not catching on and makin it do that when i try to punch it.. but im gonna try to get a f1 stage 2 clutch and a fidanza flywheel. i got the money right now but im gonna wait till my irs check comes in from the gvt. next week.. so i can get it and get it installed. but yea its a good project car for me.
Old 05-10-2008, 09:22 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
F1 stage 2? what is that? a 2100lb pressure plate? what mods you have? i bet you could rock stock for cheaper, if you arent making anything near... what guys... 300whp? my stocker didnt slip till i ran 24psi on "race gas" and link says *and i QUOTE! "383whp"... HA! i wish! but none the less, it started slipping
O.P.~ i would get an ACT clutch, they are proven to perform in the DSM's... thats what i will be gettin, thats what everyone else has, and thats what everyone will always have. becasue we know they are good... just
Old 05-10-2008, 12:42 PM
f1 clutch is off of ebay. its formula 1.. but not sure wat i have in my car.. i just got it. i kno there is a turbo. headers. prolly bout a 3 inch catback exhaust. 96 eclipse gst.
yea ive heard ACT is good. so should i go with a stage 2 or OEM
Old 05-10-2008, 03:08 PM
Black99GST's Avatar
what kind of turbo you got? if you dont know, can you spin the tires in second if you punch it at 20mph? if you can RAPE the tires in second (W/O having to pop the clutch...) then i would say stage 2 (2100lb act) is the way to go... i'm getting a 2600 6 puck... but i know where i want my car to go... check the sig
Old 05-10-2008, 09:17 PM
Smile Re: my 96 eclipse gst wont start
lol yea i can spin the tires in second easily. but umm yea i got headers a turbo and a injen intake.. so yea i guess ill go wit a stage 2.. but hopefully when i get my flywheel it will stop puttin when i floor it sometimes. has ur car ever done that?? i do need to change the oil. maybe that might be the problem.. get a tune up and shit
lol yea i can spin the tires in second easily. but umm yea i got headers a turbo and a injen intake.. so yea i guess ill go wit a stage 2.. but hopefully when i get my flywheel it will stop puttin when i floor it sometimes. has ur car ever done that?? i do need to change the oil. maybe that might be the problem.. get a tune up and all
Old 05-10-2008, 11:18 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What do you mean stop "puttin" when you floor it? What exactly does it do, does it "stutter" like it doesn't want to take off? If so, change the plugs. And get the rest of the car tuned up at the same time.
95 Talon TSI AWD
97 Eclipse GST
Old 05-11-2008, 11:51 AM
yea its sputterin.. it doesnt want to get up and go sometimes.. so thats wat i figured a tune up.. while im getting my clutch and flywheel done im gonna get a tune up.. so how much can ur car get up 2?? with speed
