Old 05-07-2008, 05:09 PM
gorman90xj gorman90xj is offline
need help with TPS,CPS,MAP?
my 90 cherokee is having some acceleration problems along with shifting problems. my pedal feels real squishy and when i try to accelerate it misses, then i have to mash on it and i get backfire from that, it shifts out of place(like it doesnt know what gear to be in).......its gotta be one of the electronic sensors...not sure which one though..i just had an exhaust upgrade as well, do i need new O2 sensors?..i changed cap,rotor,plugs,wires and my fuel pump is new...also i dont think i can check codes because of OBD-1 renix ecu...lookin for similar problems.thanks
Old 05-07-2008, 06:29 PM
Saudade's Avatar
Saudade Saudade is offline
Re: need help with TPS,CPS,MAP?
It's not OBD-1. It's just refered to as RENIX for Renault-Bendix.
Check out:
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
You need to know how to use a multimeter. My guess is start with the TPS.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 05-10-2008, 06:31 AM
gtmud gtmud is offline
If you just had the exhaust "upgraded", did youhave the exhaust manifole removed. If so I would start there, for and improper seal, causing an vac leak.
Old 05-12-2008, 08:46 PM
nope never had it removed, only from the end of the cat and back was replaced.
