Old 05-07-2008, 03:50 PM
will123 will123 is offline
bypass rear coolant lines?
The rear coolant lines that feed the rear heater on my 2001 GC are leaking. The mechanic wants $1000. to replace them (ouch!).
Can I simply bypass them somehow? Should I plug them or cut and reconnect them at the firewall? Any advice greatly appreciated.
Will
Old 05-07-2008, 06:42 PM
Bernard Feltzer Bernard Feltzer is offline
Re: bypass rear coolant lines?
cut at firewall and connect together with heater hose and 2 screw clamps. Do not plug them.
Old 05-15-2008, 10:40 AM
On which side of firewall should they be cut?
Old 05-19-2008, 07:32 PM
Vats Vats is offline
will123,
I think the easiest way to bypass is by joining the two pipes underneath the car with heater hose and two clamps.
If I am not mistaken the two pipes run side by side to the rear heater core. I have done this in the past with GM powersteering cooliing lines.
Look at where the corrosion stars on the oprigianl pipes, cut off here it begins and join with heater hose. Saves you gettin up in the firewall.
