Old 05-06-2008, 09:53 PM
JeenyusVR4 JeenyusVR4 is offline
Greddy profec b spec II
Ok so i just installed my new boost controller the other day but i had no idea how hard it was gonne be to tune. Im looking to get around 13 psi or so cuz i still have the stock turbos. Does anyone have a good starting point to set it to. If any has any good numbers to put in for the SET, GAIN, SET GAIN.
Old 05-07-2008, 09:22 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Re: Greddy profec b spec II
what year car? bc i have mine tuned for about 14.5 psi but i could give u my numbers but u would have to subtract a bit from my numbers to make sure ur not over what u want.
OH by the way, get a data logger if u dont have one.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 05-07-2008, 09:26 PM
its a '92 and would turning it up to 14.5 psi hurt anything. I have the stock fuel system other than a walbro 255 with the hotwire kit nd the metal fuel rail loop. I do have a full 3" exhaust with no cats nd y pipe with air filter.
Old 05-07-2008, 09:29 PM
ya i bought a datalogger but it only came with a connector to plug into a PC to upload the software but i only have a laptop. Any ideas??
Old 05-07-2008, 09:36 PM
where did u buy it from? and i use a laptop as well. i got a Hand Held Halo data logger.
14.5 psi is fine with the stock fuel system, how ever i would get your data logger set up first b4 u get it at 14.5. but u should be fine at 14.5
My numbers are, boost 52% Gain 31% set gain 58. you can take those numbers and take off a few numbers and work with yours from there.
Old 05-07-2008, 10:23 PM
I got mine on ebay. Its a palm III i think but the connector for the computer will only fit in a PC. But ya thanks again so much for the base numbers to start around. That is so helpful. Ill let you know how it goes.
Thanks again
Old 05-08-2008, 09:21 AM
On your car does it pull 14.5 to redline??
Old 05-08-2008, 11:46 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
stock turbos are not going to hold more than possibly 9 psi to redline. They are out of their effeciency range at that point.
Old 05-08-2008, 03:53 PM
new2mitsu new2mitsu is offline
so, if my boost gauge reads 13 to redline am i oxer boosting, or is my boost gauge innacurate? its aftermarket, and seems to be fairly accurate, and im loggin no knocks or fuel cut...
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 05-08-2008, 05:46 PM
Stealthee's Avatar
The gauge might be accurate but your source may not be.
Old 05-09-2008, 04:22 PM
hmm, i installed it right where stealth316 write up shows... jus curious
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
