Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-06-2008, 07:34 PM
Kawazar Kawazar is offline
Buzzing noise from floor
I did my intake manifold gasket this weekend and all went well. However, after I finished I could hear a buzzing or clicking noise while the engine is running. It sounds like it is coming from the drivers side transmission tunnel right where the 4WD shifter is. It does get faster when I accelerate and what is weird is it disappears when I let off of the gas and coast when I am doing above lets say 25 or 30 mph. It does it no matter what gear I am in or what gear the transfer case is in. The transmission fluid is fine. I didn't touch anything down there when working on the truck. Any help would be appreciated!
Old 05-07-2008, 11:39 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Buzzing noise from floor
hard ot say without hearing it personally
going to be blindly and wildly guessing from here on the internet
check u joints
check for something rubbing on the driveshaft or other rotating part
good luck!
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-08-2008, 06:40 PM
I got under the truck today. It makes the noise at idle and it doesn't matter if it is in gear or not. You can hardly hear it from under the truck but it is loud from the inside. It almost sounds like it is inside the transmission. It seems to change speed with the change in gears and rpm.
Old 05-23-2008, 02:10 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Are you sure its coming from the inside of the transmission? it is hard to say without hearing it. Make sure your dust cover on the front is secure. Is it possible it could be an ABS motor buzzing and going out??
