| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
guages fuse keeps blowing
well i posted in the wrong forum i guess.
look in the interior section http://www.automotiveforums.com/vbul...d.php?t=902721 i need help with this one. im trying to get the car on the road ASAP and it needs to be inspected. no guages = no sticker =
Re: guages fuse keeps blowing
what the heck here`s my guess...lol check all of the marker lights wiring, one may be shorting out taking gauges as well
Life Is A Highway ,Enjoy The Ride
ok, how do i check this?
im a complete NOOB at car electronics i have a digital multimeter but thats about it |
just look at the socket and wiring for each marker and tail light look for a spot where it has rubbed thru to bare wire and is touching bare metal causing it to short. you may have to follow the wires from back or front to where it goes into passenger compartment .
oh crap........ me bad . Got crossed up thinking it was gauge/dash lights ...sorry. looking at to many posts with too little sleep. Anyway same idea you will have to find out what all is on that circuit and trace wires and eliminate each part of circuit till you find the short . Sorry for the mislead.
I had the same thing happen on my 85 IROC years ago. It turned out that the EGR solenoid connector had an internal short and was blowing the fuse for the gauges. The solenoid is on the same circuit as the gauges.
any other theories?
im not exactly sure how to check every wire for shorts. do i check the resistance of the wire from start to the end? |
do you have a wiring diagram for your car?
nope, no wiring diagram per se.
i have a chiltons though and it covers general f-bodies |
is there anything else that you are aware of that does not work when this fuse blows or does every electrical thing work? Check the solenoid connection to which Morley pointed out.
well i dont currently drive the car as it isnt insured and has no plates.
it is parked most of the time. last time i ran it, i put a new fuse in and the guages worked. now that the fuse blew, none of the guages work. i will check to see if anything else doesnt work. |
