| View Poll Results: Do I replace the Ignition Control Module? | |||
| Yes |
1 | 25.00% |
| No |
3 | 75.00% |
| Voters: 4. You may not vote on this poll | |||
All,
So a few days ago my check engine light came on and I checked the code and had a cylinder 6 misfire. Since I hadn't changed the plugs for a couple years, I figured I'd change those and the wires and see if that solved the problem. I also found out that the plenum gasket was leaking and replaced that, resealed the injectors and all that jazz. The check engine light never came back on and the car seemed to run fine. I'll admit that it didn't purr like it has in the past, but no one would even notice but me. Well a couple of days ago, I got a recall notice from Pontiac saying that the front rocker gasket was leaking oil on the exhaust manifold and causing fires. I took it to the dealership for the free repair and they called me saying that my ignition control module was bad and that it would cost $600 to repair. I called Auto Zone and they told me the part was $130 with a lifetime warranty. I then called my usual mechanic and he told me that if the ignition control module was bad, the car would be running horrible and would be dying when the engine got to normal operating temperature. So I'm going to pick up the car this afternoon and I'm trying to decide if I should tell the dealership to go to @#$# or if I should go ahead and replace the module. My mechanic told me that if I decided to replace it, that it was an easy job (I have NO clue; this is the first car I've owned that didn't have a distributor). I'm embarrassed to say it, but I don't even know where the ignition control module is on this car. Does anyone have any experience, pearls of wisdom, advice, etc? Thanks for the help!
![]() ![]() 2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C 2000 Jeep Grand Cherokee Limited 4.7L V8 ---------------------------------------------------- 1996 Chevrolet Camaro Z28 5.7L V8 1993 Chevrolet Suburban K1500 5.7L V8 1991 Ford Probe LX 3.0 V6 1986 Ford Tempo GL 2.3L 4 cyl. |
Re: Ignition Control Module? Help?
OK 1ST NO on module!!with out diagnosing 1st.why did dealer say it was bad??im guessing u didnt go through the history of car & if its running good
i dont no why u were told module was bad. |
The ignition control module is what triggers the coils to fire via inputs from sensors feeding the PCM. As your mechanic stated, if the ICM was bad, the car would be running bad, missing, etc... It sounds like the dealership was trying to soak you. Even a Delco ICM only costs $180 or so, and takes about 20 minutes to install, so $600 is rediculous!!
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
1st things 1st - don't let the dealership change it for $600.
Next - there's no reason to give the dealership any lip, just ask why they think it needs to be changed. I'm guessing they removed it to change the valve cover & saw something they didn't like. Let us know! The ICM is the module that the coils are mounted to. Remove the 6 5.5mm bolts holding the coils & loosen the 7 mm bolt that holds the wiring harness. Pull the wiring harness out of the module & you're half way there. Seriously, 7 bolts & about 15 minutes is all it takes to swap modules. If you want an AC Delco module they're about $200 online. |
Here's another question; how exactly do they "test" an ignition control module?
I'll definitely get more info from the dealership to find out why they think it needs to be changed. He said that the car wasn't running well and it was due to the ignition control module. He didn't say anything in regard to finding damage or corrosion, or anything like that, but I'll ask when I pick it up. Thank you for the pointers! I'll make sure to update this tomorrow and let you know how it turns out.
You can test it by removing it and bringing it to the neareast autozone or advance. They will check it for free.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
SO!! Are you ready for part two of our series? So yesterday I go to pick up my car from the dealership. I declined having them change the control module. After considering all of the facts, I figured that perhaps they discovered that I was losing 1/4 of a gallon on my MPG and wanted to get a quick $600 for it; an inconvenience I was willing to live with. I walk into the office and I begin going over the "invoice." I notice that on the invoice, they had documented, "customer complains of a burning oil smell," which when I brought it in, I said NOTHING of the sort! I asked to talk to the tech because I wanted more info on this module situation. He came to the service office and I asked him how much the part was and he said $350, and labor would take 2 hours at $100 per hour. Then I asked him how they determined that the control module was bad. He said, "we can just tell by how it's running." After receiving those gems, I decided to take my keys and go. Well I went to my car, started it up and surprise, surprise, it ran worse than it ever has since I've owned the thing. Keep in mind that it was running absolutely fine when I brought it in there! My car ran how I imagine it would it all of the spark plug wires were incorrectly matched with the spark plugs. It sputtered and struggled and ran like absolute garbage. I called my usual mechanic right there and told him what had happened and he said they would be happy to look at it for me. He said that where it was running completely fine when I brought it to the dealership, it was unlikely that the module was bad. Although the car was running like it was underwater, it was still "running," and I decided to quickly run it over to my usual mechanic as he was not far from the dealership. I got about 300 yards from the dealership and became deeply concerned about damaging anything when I discovered that I practically had to floor the gas pedal to get the car to go anywhere. I quickly pulled over and called the service department manager and played the entire story for him. He said to bring it back and they'd look at it again (they were about to close so that's one more day without a car). I pulled my car in the garage and had a brief chat with our manager friend. He said that they'd take a look to see what was the matter and mentioned trying to get GM to help pay for repairs since this problem came from servicing a recall repair. I have my doubts that GM will be so generous. So here I am awaiting news from the dealership. Needless to say, the chances of me ever going there again are about as good as my chances of me becoming president of the United States. Once I get a call from these...people...I'll fill in the rest. Stay tuned for PART III of "The Dealership from the Black Lagoon."
Although the recall involves just replacing the front valve cover gasket and cover bolt grommets plus a few of the ignition wire retainers, I recall the coil packs and ignition control module to include mounting bracket should be removed since it blocks the far right valve cover bolts.
So technically if the problem developed after their work they could be responsible. Maybe they did not install it back properly or use proper sealant. Also, check the ignition control module ground wire. Although the recall is well known by the dealerships they have to annotate a trouble such as customer complains of burning smell. Without it they may not get reimbursed from GM.
Yes, the service manager did mention that they did have to remove the coils, etc. I'm really holding my breath on this one.
What do you think the chances are that any damage was caused as a result of my driving the car 300 or so yards? My usual mechanic said that there was a risk of damaging the cat. converter. I can somewhat see the logic to their putting that there was a problem (burning oil smell) for GM to pay for the recall, but I would think that the simple fact the GM themselves sent me a letter and told me to go get it fixed would be reason enough!
PART III - A New Hope
So I just received a call from the service manager. He said that after they've looked into it, they discovered that the problem was in fact the ignition control module. He said he's figuring that it was old and because it was "disturbed," it could've been enough to finish it off. He said that he's confident that it's now running better than it was when I first brought it in (we'll see). He said that GM wouldn't help with cost or anything. He said they aren't going to charge me for any labor, and his cost on the OEM module is $240. He asked if I'd be willing to just cover the cost of the part. I told him that I just barely poured $900 into repairs two weeks ago and couldn't go that high. I asked him if I could get the part from Autozone and he said he couldn't do that. He then offered to split the cost and have me pay half (which is about what the Autozone part would cost). I agreed and thanked him for being willing to do that. So do you think I got a fair deal or do you think I got screwed? (Pending my picking up the car and actually seeing for myself that it's running well.)
i think you got a pretty good deal. sounds to me like this service manager is actually a pretty nice guy and not afraid to admit to his employees mistakes. you said yourself it wasnt running "like it used to" before you brought it in. i would say if it runs like it used to when you get it back...you got yourself a pretty da*n good deal, considering the fact that you would have had to replace it at one time or another.
I'd agree with that. Now let's just hope it runs well when I pick it up!
I disagree. Ignition modules either work or don't. They don't fail from being unbolted and rebolted down unless they did something wrong. I would make sure you get the old part in your hands before you pay the bill. If it's cracked or chipped, don't give them a dime for the new one. They broke it, they replace it. That's what you're paying them for. What if they snapped off some bolts removing the valve cover gasket? Would you be willing to split the cost of a new head or the labor to extract the broken bolt(s)? I'm thinking you wouldn't. Just because they messed up a part they claim was ready to go, that's crap. They said what they said because they broke an expensive part, and didn't want to have to eat it.
He'll probably just say that they've thrown it away already. I'll try when I pick up the car.
Most states have laws governing this sort of thing. In Michigan, the consumer has the right to the return of all replaced parts, except those deemed too heavy or bulky, or that require a core deposit from the manufacturer. On those parts, you have the right to inspect them before you pay the bill. This keeps unscrupulous dealerships and shop owners from claiming the replaced parts that they didn't.
