Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-05-2008, 08:08 PM
monogee monogee is offline
My 2005 Yukon Denali Window Won't Roll Down?
All my windows roll down except for my rear passenger side window. Does anyone know why? Is it possibly a fuse might have blown. Thanks.
Old 05-07-2008, 04:57 PM
bcopeland bcopeland is offline
Re: My 2005 Yukon Denali Window Won't Roll Down?
Power windows, I assume. There are fuses for each window under the hood. I would check that first. Then, maybe the window supports are binding?
Old 06-06-2008, 12:15 AM
bungnati bungnati is offline
Motor may be bad, regulator could be jammed. I would go the easy way first and look for blown fuse, then listen for the motor trying to move the window. If you dont hear the motor its probably bad. If you hear the motor it may be the regulator.
Old 07-12-2008, 07:04 PM
I had the window checked. It is the motor. Would anyone know how to take the inside of the rear passenger door off? I bought a new motor and it's so small, I believe I could replace it myself. Thanks.
