Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-05-2008, 12:39 PM
druidrv druidrv is offline
TH 350 Question
This TH-350 dose not go into gear and is not pumping fluid through the trans cooler. This is the second trans we have put into this truck to have the same symptom. The only thing we reused was the torque converter. The second trans was gone through with new clutches and filter. Can the lack of fluid pressure be caused by the converter? It is a near stock stall B&M around a year old with no visible damage.
Old 05-06-2008, 11:37 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: TH 350 Question
Fluid level full when engine running in park?
If no cooler line pressure speed engine up just a little.
Have you check transmission pressure?
If no pressure front pump may not be pumping.
Is the pump gear tabs broke off.
Did you have converter end play when transmission bolted up?
MT
Old 05-06-2008, 04:54 PM
SLJ2137694 SLJ2137694 is offline
Re: TH 350 Question
Good point about the torque converter that may not be properly indexed to the front pump. I have seen this happen more than once by some inexperienced wanna-be technicians.
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 05-06-2008, 06:57 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: TH 350 Question
... and it results in death to the front pump.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-06-2008, 09:19 PM
Re: TH 350 Question
Wanna be tech. I may not do this for a living but this is not my first dance either. The trans went in fine and no I did not pinch the converter. The question was, can the lack of fluid pressure be caused by a defective converter. If not, then the trans was rebuilt wrongly by a real life, professional tech.
Old 05-06-2008, 11:01 PM
silicon212's Avatar
Confoundingly Lucid
Re: TH 350 Question
The torque converter must be properly indexed in the transmission. There are three 'clicks' on a perfectly indexed converter - the first when the input shaft indexes, the second when the stator indexes and the third happens when the front pump indexes. You may think it's fully indexed, and indeed the converter will fit between the flexplate and transmission (without binding) if the input and stator are indexed but not the pump. It's easy to miss if you're not 100% careful, such as if you're in a hurry to get it on the road; I've been guilty of that myself once which is why I can write about it here. I hope you don't view this post as a knock on your skills - it isn't.
A failure of this type is considered an install failure, not a build failure, so your trans tech is not responsible if you installed the transmission yourself.
Of course, this is all hinging on whether or not the front pump (broken gears) is the problem. There are other things that can cause this - low oil level (did you put at least 8 to 12 quarts of fluid in it when you installed?) is a chief culprit.
8 quarts if you're reusing a torque converter, 12 quarts if you have a new/rebuilt converter.
Old 05-07-2008, 08:58 AM
MT-2500's Avatar
AF - Advisor
Re: TH 350 Question
The converter does not pump up the pressure.
It job is to turn the front input shaft into the transmission just like the input shaft on a standard transmission.
Only it is coupled to the engine with hyd. turbon fins instead of a solid disk.
The front pumps pumps up the hyd. and line pressure in the transmission.
MT
Old 05-07-2008, 10:29 PM
Re: TH 350 Question
No offence taken on my skills as they are extremely limited. Thanks for answering the converter question. I didn’t think it was the problem. I never had a problem indexing the converter before, but we were pushing to get it back on the road. I will double-check the indexing. That is probably the problem. Many thanks for the info. Ron
Old 05-08-2008, 08:27 AM
MT-2500's Avatar
AF - Advisor
Re: TH 350 Question
You are welcome.
Make sure it is full of fluid and put a pressure gauge on it and if no pressure it will have to come back out.
If you pull it back out open up the front pump and chech the pump gears.
If yhey are OK you will have to go deaper in it .
Good Luck
MT
MT
Old 05-08-2008, 08:59 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: TH 350 Question
From my experience with a torque converter not being "home", it has been obvious and can prevent you from bolting up the transmission to the engine. I always replace the converter when I swap a transmission, I used to get a good deal on rebuilt ones at my local Aamco.
I have made up a couple of simple brackets that hold the converter in place while I install transmissions. It bolted to one of the flywheel inspection pan holes, had a slot sawed in it that picked up one of the mounting brackets on the converter. You should have around a 3/8" gap between the flywheel and the flex plate once the tranny case is bolted up to the block. Which will difer from model to model.
Bob
