Old 05-05-2008, 10:23 AM
ghalacsy ghalacsy is offline
96 fuel pump control module
just wondering where the fp control module is at and what its part number is. i've been working on my car for over 2 months and i've finally narrowed down my problem to either the ignition switch or fp control module.
thanks,
guy
Old 05-05-2008, 10:58 AM
Mickey#1 Mickey#1 is offline
Re: 96 fuel pump control module
You should be able to get a part# from RockAuto.com or GMpartsirect.com. Their mounted on the left side of the trunk on Bonnevilles. I don't know if the Park Aves are the same. We haven't seen much trouble from these, what's the car doing?
Old 05-05-2008, 11:15 AM
well after i changed out the crank sensor it would still stall. now it is stalling whenever you use almost anything electronic. biggest culprit is windows and door locks.
Old 05-05-2008, 11:24 AM
That may be an easy & free fix. I'll add a link to this post in a few minutes.
Here's the link. See if the Park Ave has the ground bus in the same area & let us know what you find.
http://www.bonnevilleclub.com/forum/...=article&k=102
Old 05-07-2008, 12:19 PM
mickey#1 that did it. exactly where you said it woulod be. big suprise it was corroded... the pad under the carpet was wet from working on the car in the winter. got it fixed and runs beautifully. again thanks.
guy
Old 05-07-2008, 12:28 PM
Glad you got it fixed. As soon as you mentioned the power windows & locks I was 99% sure where the problem was.
BTW- is this a Park Ave Ultra? Only the supercharged engines have the Fuel Control Module.
Old 05-08-2008, 06:56 AM
no its just a regular park. the service manual didnt mention that it was only 4 ultras.
again thanks a lot
Old 05-27-2008, 04:16 PM
crzylgs crzylgs is offline
The link isn't working for me currently. If you could tell me where that ground bus is located I would greatly apperciate it. I have the same problem currently.
Old 05-27-2008, 05:42 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: 96 fuel pump control module
Click Here for the same info. The site to which the link above directs you, is going through some changes.
Old 05-28-2008, 03:18 PM
Here's some more pics.
