Old 03-04-2003, 04:00 PM
fisherman101 fisherman101 is offline
Banned
Question programming remote 01 Lasebre
Anyone know if you can reprogram the 01 buicks for new remotes like the older ones or do you have to go to dealer? Thanks for any help
Old 03-04-2003, 07:22 PM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
John or bowtiebandit will help out a ton on this subject. I'll pm one.....
Old 03-05-2003, 06:54 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
The dealer will have to program this one for you unless you know someone who has a scan tool..
<HR>
</FORM>
<H1>Transmitter Programming</H1>
<P><FONT COLOR=brown>
<H4>Important</H4><P>All transmitters which are to be recognized by the remote control door
lock receiver (RCDLR) must be programmed in a single programming sequence.
If the system is placed in program mode, all previously programmed transmitters
will be erased upon the receipt of the programming signal from
the first transmitter. Up to four transmitters may be programmed. Do not operate
or program the transmitters in the vicinity of other vehicles that are in
the keyless entry program mode. This prevents the programming of the transmitters
to the incorrect vehicle. The order in which the transmitters are programmed
is important. The first transmitter programmed will be transmitter&nbsp;#1,
and the second transmitter programmed will be transmitter&nbsp;#2. The number
on the transmitters are for reference only:&nbsp;#2 can be programmed as&nbsp;#1,
or vice versa. Additional unnumbered transmitters are also available. Use
care to program the transmitters correctly.</P>
</FONT></P>
<OL><LI TYPE="1">Install a scan tool.</LI>
<LI TYPE="1">Turn ON the ignition, with the engine OFF.</LI>
<LI TYPE="1">Use the scan tool Remote Function Actuation Special Function:
Program Key Fobs in order to place the remote control door lock receiver into
Program Mode. The doors will lock and then unlock in order to confirm
program mode.</LI>
<H4>Important</H4><P>The scan tool must stay connected until all of the transmitters are
programmed.</P>
</FONT></P><LI TYPE="1">Press and hold the LOCK button and the UNLOCK button simultaneously
on one transmitter. After a delay of 15&nbsp;seconds, the doors will lock
and unlock in order to confirm the programming of that transmitter.</LI>
<LI TYPE="1">Repeat the previous step in order to program up to 4&nbsp;transmitters.</LI>
<LI TYPE="1">Remove the scan tool.</LI>
<LI TYPE="1">Operate the transmitter functions in order to verify correct system
operation.</LI>
</OL>
Old 03-05-2003, 03:52 PM
Banned
Thanks for answer on remote
Thanks .. have fun and enjoy
Old 01-03-2005, 05:18 PM
dmadrr dmadrr is offline
Re: programming remote 01 Lasebre
What is a fair price for a dealer to do program the remote? I have been quoted $70 and $45; is this price range fair, or should I keep looking?
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 12:00 PM
Programming Transponder Key North_star Eclipse 2000+ 0 04-06-2010 06:20 PM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
