Old 05-04-2008, 10:44 AM
glc4122 glc4122 is offline
97 gp codes
yes, i own a 97 pontiac gp 3.8 engine. the check engine light has been coming with codes #171, 336, 402 what is the problem. all help would be appreciated. some times the tachometer will quit working while driving, once i stop and turn of engine it will work again.
thank you
Old 05-04-2008, 11:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 97 gp codes
The DTC of concern and probably causing the tach issue is the P0336 which is a crank position sensor range/performance issue. Not sure but it may cause the other DTCs to set so get that taken care of first as far as priority.
P0171 is a lean condition and a fuel trim DTC and P0402 is an EGR related fault. Flow too excessive.
Timeslip 08/12/06
AF Community Guidelines
Old 05-04-2008, 11:55 AM
Re: 97 gp codes
thanks for the help, so take care of the crankshaft postion sensor, is it hard to install and if so would you have and diagrams of the location.
thank you
Old 05-04-2008, 12:11 PM
BNaylor's Avatar
Re: 97 gp codes
You're welcome.
We have a DIY procedure posted at our Tips & Maintenance forum. See link below.
Click here
Also, be sure to clear the DTCs after CKPS replacement and then see if the DTCs reoccur. Good luck.
Timeslip 08/12/06
Old 05-04-2008, 07:11 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 97 gp codes
Funny a Bad CKPS would set a DTC isnt it? I've never had that happen on a 3800 before.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-24-2008, 01:24 PM
Re: 97 gp codes
yes, i tried to replace the cps and been having troubles with the removal. the nut on the end of the pulley,will nut turn, the whole pulley turns,is there a trick in loosening it. i don't have a impact?
