Old 05-04-2008, 09:50 AM
fordzx298 fordzx298 is offline
Timing belt trouble Ford Zx2 1998
Hi,
I'm having trouble with my car (Ford Zx2 1998). Its timing belt broke while it was being driven. Does anyone know for sure if it caused any damage to the engine (valves or anything else)
I already posted this at Ford forums but it must fit better here.
Thanks.
Old 05-04-2008, 12:16 PM
maxwedge maxwedge is offline
A990 racer
Re: Timing belt trouble Ford Zx2 1998
My Dayco book shows it is a freewheeler.
Old 05-04-2008, 12:44 PM
UncleBob UncleBob is offline
AF -Advisor
if its the ZTec motor (2.0 DOHC) you likely bent valves
If its the "split port" motor (2.0 SOHC) you're good to go
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-04-2008, 01:19 PM
Is there a way to know which one it is?
Old 05-04-2008, 01:35 PM
AF -Advisor
It will say "ZTEC" on the valve cover, or "split port induction" on the valve cover
Old 05-04-2008, 10:34 PM
There is nothing on the engine or valves.
Old 05-04-2008, 11:54 PM
AF -Advisor
thats odd...
whats the 8th digit in the vin #?
Old 05-05-2008, 12:08 AM
AF -Advisor
I should have looked this up before. The ZX2 only came with the dohc engine (that was the "high performance" version of the escort). I'm sorry to say, thats an interference engine
Vin code "3".....8th digit if you want to verify
its still possible that the valves didn't get bent....but its not very likely
Old 05-05-2008, 07:56 AM
How much does it normally cost to replace the engine (excluding the cost of the engine) and how much would the engine cost?
Old 05-06-2008, 12:23 AM
AF -Advisor
you shouldn't need to replace teh engine, just pull the head and have the head fixed.
Its still not cheap, but its a lot cheaper than a motor
Not only is the motor a lot more than the cost of getting the head fixed, the labor is quite a bit more for the motor
