Old 05-04-2008, 10:26 AM
roachd2 roachd2 is offline
TPS Replacement
On a 3800 series II the bottom screw on the TPS is immossible to remove. Do you have to take off the thermostat goose neck to remove it or is there is trick or special tool?
Old 05-04-2008, 10:49 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: TPS Replacment
It is not impossible however GM used threadlocker on the TPS screws so it is not uncommon to have the screws break off. Unless you have the right 90 degree Torx allen wrench you'll probably have to remove the thermostat housing. Also, depending on the year the TPS screws may be the Torx tamper proof type so you will need a Torx T20 tamper proof bit.
Timeslip 08/12/06
AF Community Guidelines
Old 05-07-2008, 12:58 PM
OJ_ OJ_ is offline
Re: TPS Replacement
Besides a tamper proof torx bit, nothing special is needed to remove the bolt.
You can use a wrench to turn the bit, it is kind of awkward but it beats spending time removing air bubbles from the coolant system due to removing the tstat elbow.
2001 Silver GTP Coupe
Self-Tuned - HP Tuner, 1.9s, 105s, Coated Pacesetters(no cat), Poly MM, EGR del, ZZP 1.0 PCM, ZZP MPS 3.25-3.4, AL 104s, Wizair, TBS, 180 tstat, Falken 512s
Old 05-07-2008, 02:47 PM
BNaylor's Avatar
Re: TPS Replacement
The TPS is a critical sensor so better to do the job right the first time. I would drain some coolant and remove the thermostat housing and it is no big deal topping off the coolant and doing an air bleed. The most compelling reason is it would be impossible to properly torque down the bottom TPS retaining screw which should be torqued with a torque wrench. 216 in-lb or 18 lb-ft per GM specs. Low to med strength threadlocker should always be used on the TPS screws. Those screws along with the IAC screws have a tendency to loosen up over a period of time if not secured properly.
Timeslip 08/12/06
Old 05-07-2008, 04:47 PM
OJ_ OJ_ is offline
Re: TPS Replacement
This man cannot lie, it would be ideal to follow his instructions.
