gas line question
I am getting rid of my 1989 grand prix 2.8 liter and have half a tank of gas in it. I want to take the gas out off it and syphoning is not working. Is there some where to disconnect
the fuel line inside the engine compartment and use the fuel pump to empty the tank. Thanks in advance, Roger |
Re: gas line question
Yes there is, but you need a fuel pressure guage.
Hook it to the fuel rail, then locate either the fuel pump relay, or sometimes GM puts a fuel pump lead somewhere in the engine compartment. Its usually red. You can either jumper the contacts of the relay, or you can connect this red wire to B+ and the pump will run.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
You can also jack the rear of the car and support it on stands, disconnect the fuel filter on the engine side and attach a rubber hose running to your gas cans. Turning the pump on can be done safely as previously suggested since you are totally away from anything electrical.
