Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-03-2008, 01:02 PM
evildragon evildragon is offline
optispark
Ok, how come everytime i search for an optispark for my 94 caprice they show the vented ones?
didn't the vented ones come out in 95? i went under my car, and sure enough it's a vented one.. when i had the motor swap, they used the same year motor..
so um, are the LT1 people innacurate in saying the vented one came out in 95?
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 05-03-2008, 01:31 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: optispark
For GM B bodied vehicles the "vented " Optispark was first used in 1994. The following year it was used on other models that had an LT1 engine.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-03-2008, 02:25 PM
Re: optispark
ok thanks, purchased a new optispark with cap and rotor for about 150 on ebay.. says it exceeds OEM specs..
my opti didn't last for long (since LT1 motor swap). wow..
L99 Engine
Old 05-04-2008, 02:59 AM
burnM's Avatar
burnM burnM is offline
Re: optispark
What brand did you buy? Can you post a pic of it?
I'm only asking because I recently bought a '95 9C1 and am new to the opti-spark system. Vented or non-vented, how can you tell?
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 05-04-2008, 07:50 AM
96capricemgr 96capricemgr is offline
Re: optispark
All b-bodies got the vented setup, simple as that.
IMO most optis replaced as "bad" just needed a new cap and rotor.
People have it stuck in their head it is a bad piece but at the same time what other distributor can you leave the cap and rotor untouched for 100K miles???
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 05-04-2008, 09:01 AM
Blue Bowtie's Avatar
Registered Offender
Re: optispark
109K for me. All it needed was a cap and rotor (vented, of course), and general cleaning of the rest of the parts.
Old 05-04-2008, 09:52 AM
j cAT j cAT is offline
Re: optispark
before you replace the opti cap/rotor make sure the water pump is not leaking at the weep hole. in any case when reinstalling the water pump install a weep hole drain tube that will direct the coolant far away from the distributor....this was a mod. that i found in 1996 as a way to prevent opti destruction...
Old 05-04-2008, 12:41 PM
Re: optispark
The sensitivity of the opti to water and coolant is GROSSLY overstated by the sheelpe of the internet.
Currently own LT1 3 b-bodies 125K, 180K and 227K I have owned them for over 180K miles total and have never had an opti failure only had one cap and rotor wear to the point it affected performance. Do not hesitate to drive through standing water, had several WPs weep had a heater hose get cut and dribble all over the front of the engine, wash the engine, etc.
I have not bothered to mess with routing the weep hole drainage because if it starts to dribble I notice it before total failure and the opti doesn't get any wetter than in normal rain conditions. First sign of weeping is usually the PS feeling like it looses assist for a second during low speed turns, this is the belt slipping due to the coolant.
Old 05-04-2008, 12:46 PM
Re: optispark
I don't remember, my father purchased it on his ebay account.
I think it was from "Import Experts" or something like that.. says it was made to exceed OEM specs.
L99 Engine
Old 05-04-2008, 04:31 PM
burnM's Avatar
Re: optispark
Great info, thanks guys.
