Old 05-03-2008, 09:43 AM
Bryan22 Bryan22 is offline
PA Vacuum Question
On my 97 PA when the engine is running, if I remove the oil filler cap there is a noticeable vacuum and then the engine runs rougher. I put the cap back on an she is running prefect. Is this normal?
Also, where is the PCV located on this engine?
Thanks!
Old 05-03-2008, 10:20 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: PA Vacuum Question
The "vacuum" is an indication that your PCV is working as intended. If you want to know where it is and how to change it; Click Here
Old 05-03-2008, 10:34 AM
Mickey#1 Mickey#1 is offline
There should be a slight vacuum in the crankcase. I don't believe it should run rough when the cap is removed. I'd change the PCV valve & check the condition of any O rings.
Old 05-03-2008, 10:51 AM
There is a good vacuum suction when you go to pull the oil cap off. It is not really sublte vacuum.
