Go Back   Automotive Forums Car Chat > Cars in General
Old 05-03-2008, 12:30 AM
cmant cmant is offline
Banned
Best way to increase mileage
What are possible best ways to increase car mileage?
I have been equipped with this knowledge.
  1. If your car is equipped with overdrive gearing use it as soon as your speed is high enough.
2. Keeping a constant speed is ideal for improving your gas mileage.
Waiting for suggestions
Old 05-03-2008, 01:51 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Best way to increase mileage
Here are some more:
1) Keep your car properly tuned up including clean air filter.
2) Keep your tires properly inflated.
3) On the subject of tires, make sure they are properly balanced. An "off balanced" tire can cause problems as it doesn't properly make contact with the road and causes undue stress on the vehicle causing economy to suffer.
4) Remove any unneeded or excess weight from vehicle.
5) Use proper grade of fuel designed for engine.
6) Combine trips.
7) Keep from excessive speeds, prepare to brake and do not brake "at the last minute" when approaching light or stop sign, anticipate it.
8) When taking off from a stop, gradually increase speed, do not "floor it".
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-04-2008, 11:52 AM
SLJ2137694 SLJ2137694 is offline
To add to the previous list: 9) Use synthetic lubes where you can. The improvement will be slight but you will enjoy other benefits as well.
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 05-04-2008, 07:13 PM
One great benefit of using synthetic that most people don't think of is that it lessens our dependence of foreign oil. Also the longer service time is a definite positive as it decreases the quantity of used oil that needs to be disposed of whether it be recycled or by some other means, (hopefully environmentally friendly ways.)
Old 06-19-2008, 10:12 AM
jbird6178 jbird6178 is offline
There is a new craze out about running you car on water. Check it out, it has been proven to double your gas mileage.
Old 09-30-2009, 01:57 PM
Originally Posted by PBFreeland View Post
How can you tell what grade of fuel your engine needs?
Your owners manual has what the proper grade of fuel your vehicle takes. Most vehicles on the road can safely use 87 octane gas in the US. A small percentage of vehicles require a higher grade of fuel (89 or higher,) and that info is listed in your owners manual as well.
