Old 05-02-2008, 10:46 PM
Catterman Catterman is offline
Trouble code P1414
My mother-in-law has a 1999 Taurus with the FFV 3.0. SHe has been driving around for I don't know how long when I showed her that her service engine light was on... I have a scanner and came up with
P1414
Secondary Air Injection System Monitor Circuit High Voltage
I cleared it and when she was back two weeks later it was still there. Any idea what I should look at? Thanks!
1998 Honda Odyssey LX
1996 Mercedes Benz SL320
1977 Ford F-150 Custom 351M, auto, 4x4
1971 Pontiac Bonneville 455 V8, 2 door with 54k miles
Old 05-03-2008, 10:20 AM
danielsatur danielsatur is offline
Re: Trouble code P1414
Secondary Air Injection system = SMOG pump
Check for fuses or stuck relay!
Old cars had alot of problems with pumps that locked-up,because of age + just not
being used.
Old 05-03-2008, 12:41 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Sometimes water gets in them and during winter, they freeze and destroy the internals.
Old 05-03-2008, 11:37 PM
I don't think I have ever heard of a Smog pump, where do I find this and test it? Thanks again!
Old 05-04-2008, 01:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The smog pumps were used in the late 70s and early 80's and were belt driven. The GM pumps in particular seized up quite often and would burn through the belt.
On the Taurus, my recall is the air pump (which is electric on the Taurus) is located in front of the right front wheel, behind the inner fender liner.
-Rod
Old 05-04-2008, 02:11 PM
shorod's Avatar
SHO No Mo
According to the factory service manual, "DTC P1414 indicates electric AIR pump commanded off, but PCM indicates electric AIR pump is on."
"Possible Causes:
-- Open EAIR circuit.
-- Open AIR pump ground.
-- EAIR circuit short to power.
-- Damaged AIR pump.
-- Damaged solid state relay.
-- Damaged PCM."
If you'd like a PDF copy of the diagnostic routine to troubleshoot this code, send me a Private Message with the request AND an e-mail address for you that can accept PDF attachments.
Also, from what I can tell from a quick look in the manual, the AIR pump is on the left side of the car, behind the bumper.
-Rod
Old 04-05-2009, 04:44 PM
steviej123 steviej123 is offline
Smile Re: Trouble code P1414
Hi:
Any help here would be appreciated........
Thanks, stevej
"Possible Causes:
-- Damaged PCM."
-Rod
Last edited by steviej123; 04-05-2009 at 04:47 PM. Reason: didn't realize this was public............
