Old 05-02-2008, 09:01 PM
lilrebel lilrebel is offline
ac clutch
I have 1991 chevy k1500 the ac clutch is squealing can that br removed to put new one on thank you
Old 05-02-2008, 09:15 PM
j cAT j cAT is offline
Re: ac clutch
did you replace belt/or check tension ?
Old 05-02-2008, 09:25 PM
Re: ac clutch
yes did both when replaced alternator
Old 05-02-2008, 09:29 PM
Re: ac clutch
does it squeal with a/c off ?
Old 05-02-2008, 10:21 PM
Re: ac clutch
yes when i put wd 40 in the clutch stops for little bit does the clutch come off or have to replace the whole thing
Old 05-03-2008, 09:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ac clutch
Yes the clutch can be replaced.
A few special tools required.
But Make sure it is the clutch and not the belt slipping.
Does it squeal with ac off?
What is the high side on AC reading when it squeals?
MT
Old 05-03-2008, 02:15 PM
Re: ac clutch
because the the clutch makes noises with the a/c off.....you will need a new a/c compressor pulley bearing.....because of the age of this i would replace this with a scrap yard compressor or if a/c is not required use a pully bypass or belt change to bypass this compressor...if you don't do this it will sieze and you will be stuck....
yes the compressor can be repaired but it is rare for anyone to do this and the tools are not that available in my area... maybe you can find a shop that will repair this for less than 500.oo....a new one willl cost 800.oo total..
Old 05-03-2008, 06:14 PM
brcidd's Avatar
brcidd brcidd is offline
Re: ac clutch
I repair those everyday in the warm months- I have all the tools and parts-- but I don't suppose you live in Ohio--I have seen belt squeal due to the belt being wrapped wrong on 5.7L engines- I don't suppose this is you case though
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-03-2008, 08:45 PM
MT-2500's Avatar
AF - Advisor
Re: ac clutch
Check around.
You can get the compresser and clutch for just a little more than just the clutch.
O'Reilly has new compressers with clutch for 170 US $ and rebuilts for 130$.
MT
Old 05-04-2008, 01:44 PM
Re: ac clutch
Originally Posted by MT-2500
Check around.
How do i remove the compressor and clutch from the bracket do you know
Old 05-04-2008, 01:57 PM
MT-2500's Avatar
AF - Advisor
Re: ac clutch
Take the belt off and unplug electrical plugins.
And the unbolt compresser mounting bolts.
If replacing compresser you will need to be R-12 certified to pump out and recover any R-12 freon in it.
If the system is empty just unbolt compresser low and hight side lines.
Most new compressers come set up for the new R-134a gas.
You will need to replace reciever /dryer and install reto fit fittings for the R-12 to R-134a change over.
Canada may require certification for R-134a system repair or recharge.
MT
Old 05-04-2008, 02:24 PM
Re: ac clutch
i did all that took the 3 bolts out that was holding the compresser but it still does not move do we need a special tool
Old 05-04-2008, 02:34 PM
MT-2500's Avatar
AF - Advisor
Re: ac clutch
Make sure you removed all bolts.
Some will be tight against bolt tighting sleves.
Take a big screwdriver or bar and move copresser fordard if it will move or just pry up and wiggle it and it should come out/off.
MT
MT
Old 05-04-2008, 02:44 PM
Re: ac clutch
MT
Thank You finally got it off thank you
Old 05-04-2008, 03:16 PM
MT-2500's Avatar
AF - Advisor
Re: ac clutch
You are welcome.
Some of them are sure tight.
What way are you going on clutch or compresser?
MT
MT
