Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-02-2008, 04:09 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
fuel level gauge????
hey..so i noticed the other day that my gas gauge was stuck on 1/4 tank..this is the first time i noticed it..i reset my tripometer everytime i fill up my gas so i know how many miles i get to a tank..so i filled it up and the needle went back up!!! but its kinda stuck at 1/2 tank know but it does move just its not reading right..i assume its the fuel level sensor? which is on the fuel pump? which is in the fuel tank..which sucks! any advice
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 05-02-2008, 04:52 PM
Will Help Will Help is offline
Re: fuel level gauge????
Typical diagnosis of gage rheostat failure. Solution is to pull the tank. Not sure if this is a one piece unit ( gage, pump, strainer ) or seperate parts. Most newer cars are one piece units and cost like hell. If you have some miles on it, I would change everything while it was apart. Just be sure to run your tank down before you start. Gas is about 8 pounds per gallon. 10 gallons = 80 pounds extra weight.
Old 05-25-2008, 01:08 AM
Wattsyurz's Avatar
Wattsyurz Wattsyurz is offline
Send a message via Yahoo to Wattsyurz
A bit late, but on the vette forums they say bad fuel can foul the resistor strip. Sorry I don't have more details, but it may be premature to drop the tank.
'67 Camaro 350 - driver, '83 Z28 305 (off the ECM), and T5
'91 RS 305 T5, 2000 C5 2000 Trans Am
I don't drive the Fords
Old 05-26-2008, 09:50 AM
gorgepr gorgepr is offline
that exact same thing happened to me on a 94 camaro and it was the thing that floats on the fuel that was stuck on a plastic thats inside the tank, I just took it out, and problem solved
