Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-02-2008, 03:45 PM
Hubmen Hubmen is offline
Ac fuse
Hi, Pontiac Montana 2000,
Ac fuse blew out. I checked the fuse box near battery, on fender, fuse 28 AC clutch. Could also have something to do with the fan. After changing this fuse, AC worke fine. Any solution as what cause this.
Humen Montreal
Hubmen
Old 05-16-2008, 08:28 AM
Will Help Will Help is offline
Re: Ac fuse
If you are low on referigerant it can heat up and possibly blow the fuse. There is a thermal limiter switch incorporate into the system that should sut the system down to keep from cooking the compressor. If the compressor is having some problems already it could cause the clutch to heat up with resistance. You might purchase a small gage at the auto parts and check your a/c charge.
Old 05-16-2008, 09:12 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Ac fuse
Dexcool coolant is known to "eat" into the coil on the compressor causing a short in the windings- although this was primarily on C and H bodies- it possibe to happen on any application like your U-van. Have you had any water pump leaks - or other coolant leaks near the compressor?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-17-2008, 09:59 AM
Re: Ac fuse
Hi, I had the AC recharged as was low on refrigerant, after reading your message. TUVM problem solved
Hubmen
Hubmen
