Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-02-2008, 02:21 PM
dntchke dntchke is offline
Exclamation 89 Buick Ignition replacement
I need a hand here. I have an 89 Regal that I recently got moving again. I went to move it and the keys are history. Can I replace the Ignition without having the old Keys? If I can how do I go about it? I really appriciate the help on this one.
Old 05-02-2008, 03:07 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 Buick Ignition replacement
You can buy an ign switch with new keys, the how to can be found at autozone.com, repair guides.
Old 05-02-2008, 03:25 PM
The guide says I need to be able to put the ignition in the "Run" Position. Can I do this with out having the keys?
Old 05-02-2008, 06:51 PM
A990 racer
Nope, you will need to brake the locking pin.
Old 05-03-2008, 09:21 PM
How do I break the locking pin?
Old 05-04-2008, 08:08 AM
A990 racer
We use a small slide hammer, with a screw attachment at the end, screw it into the switch and pull it out, anyway you do this can damage the lock housing, you made need some professional help with this, sometimes this type of repair is beyond a DYER.
Old 05-04-2008, 08:27 AM
Mickey#1 Mickey#1 is offline
If it's not too late - call a dealer & see if they can cut a key from the VIN.
Old 05-04-2008, 12:14 PM
A990 racer
Gm does not have records for key numbers back to 89, I tried this last year on a 92, no good, also they will not do this over the phone as you must prove you own the car.
Old 05-04-2008, 12:43 PM
I know someone who had it done in January for a 92 Lumina. I figured it was worth a phone call to find out.
Old 05-04-2008, 03:11 PM
A990 racer
I agree, but a phone call will not suffice, again you must prove you own the vehicle or you know an employee in a management position. as it requires a dealership authorization code to access the info.
Old 05-04-2008, 03:45 PM
The phone call is just to find out if they can make one for his car.
Old 05-04-2008, 05:14 PM
Thanks guys Ill tr7y the dealership to see if they can cut one and if they cant ill probably junk it or something thanks again
