Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 05-02-2008, 01:19 PM   #1
JStumpalump150
JStumpalump150's Avatar
is my clutch messed up?
so i was backing out of my driveway this morning and shifted from reverse to drive and it jerked the car and thought it was no big deal but when i was driving out of my housing complex at like 15 mph it kinda jerked a little when it shifted from first to second but it wasnt anything real noticable, but when i was driving on the road and it shifted at like 35mph from first to second it felt like i was going to get launched out the window and each time it would shift from one gear to another it would jerk.
could it be my clutch cuz it only happens when it shifts and how much do you think it will be costing me to fix it?
and for those who dont know its an automatic 4 speed
any help would be nice. thanks
2002 Nissan Sentra SE-R Spec V w/6 Speed Manual
JStumpalump150 is offline   Reply With Quote
Old 05-02-2008, 04:03 PM   #2
Classicrocjunkie
Lifted GMT-360!
Classicrocjunkie's Avatar
Send a message via AIM to Classicrocjunkie
Re: is my clutch messed up?
Do a filter and fluid change. Then let us know what happens.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Classicrocjunkie is offline   Reply With Quote
Old 05-02-2008, 04:53 PM   #3
JStumpalump150
so my dad came home and the first thing he went to check was the trans fluid and guess what.... there is no dip stick to check it with and i called advanced auto parts and they said they dont carry it and it cant be ordered and when i looked into the owners manual it says the 4 speed auto trans is not owner servicable thus meaning no need for the dip stick.
so we are eye balling it and we slowely put 1 quart in while testing it every like 1/4 quart to make sure we didnt put too much in and that didnt work so we just keep putting more in till we can see it and so far we have put 3 quarts in. we took it out for a drive and that fixed the problem for like 1 mile then back to crap so we think thats the problem and it just needs more cuz it probly dispersed in the trans when we took it out and made it go crappy again.
but here is the thing that blows my mind.... how does 3+ quarts of fluid just magicly disapear over night with no red puddles in the driveway?? i mean it was perfect yesterday and now this morning its crap, dont you think it would have shown signs of losing fluid over time and not just within 10 hours?
and we checked the oil, and coolant to see if it was leaking into the engine and its all clean so the trans fluid must be the magic disapearing kind
Old 05-02-2008, 06:08 PM   #4
JStumpalump150
ok, we figured out how much to put in and 3 quarts was about right but that didnt fix the problem cuz there was a broken wire that leads to the trans and that just needed to be reconnected but if that wire was not broken i would not have put the missing fluid in and would have probly blown the trans later on so i guess its a good thing.
Old 05-02-2008, 06:22 PM   #5
kirkwood158
kirkwood158's Avatar
How to check 4-speed automatic trans., 4T40E lift car up LEVEL high enough to get under car .Start car and shift through all gears and run for at least 5 minitues get to temp. and shift through gears again getting trans temp up . pull plug out of trans. located near tail section just above trans. pan and just about across from oil drain plug..and below exhuast pipe. Use oil catch pan just incase it has some fluid in it to leak out. If no fluid leaks out add at top till it does keep car running while checking!!! ....CAUTION don't kill yourself 4-proper jack stands required PG. 1-28 of haynes repair manual GET a book it's worth it
IF I JUST DID IT RIGHT THE FIRST TIME
kirkwood158 is offline   Reply With Quote
Old 05-03-2008, 11:58 AM   #6
jakegday
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
just for future reference, its a torque converter, not a clutch
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
jakegday is offline   Reply With Quote
Old 05-04-2008, 11:24 PM   #7
Classicrocjunkie
Lifted GMT-360!
4t40e < F23
