Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 05-01-2008, 11:02 PM
Budjr52 Budjr52 is offline
Fuel Gauge not reading right
hi on my 91 lumina apv the fuel gauge reads 1/4 of a tank and I ran out of gas. a mechanic told me it is no longer reliable but yet it will bounce up past full alot then full and seems steady as it goes down. can it be a ground problem and if so where do I find the ground for this so I can attrempt to fix it..thanks...
Old 05-02-2009, 12:20 AM
vion vion is offline
Re: Fuel Gauge not reading right
Hello. My 93 lumina does the same thing, empty at 1/4 tank. Sorry that I don't have a fix for you. Sure hope someone replies that will help us both.
Old 05-02-2009, 08:41 PM
LMP's Avatar
LMP LMP is offline
My '93 Transport does the same...fuel pump starts pumping air when seemingly still 1/8...I did run empty once.. I simply think the resistor track (part of FPunit) is damaged, which is quite possible with wound resistors. I simply know where the new "empty mark" is on the gauge now, and I live with it. I've no plan to drop the tank and remove the feul pump unit for that. AS long as the pump pumps....it will stay there.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
