Old 05-01-2008, 09:08 PM
02wgn 02wgn is offline
engine miss or trany problem ?
Hey guys,I cant seem to tell wether i have a engine miss ,or tranny problem.At around 15-to 2000rpms,my 02 taurus wagon with a 3.0 litre vulcan engine seems to shake,run rough.It doesnt hesitate,there are know engine lites on,plugs and wires done 10,000 mls. ago,replaced ig. coil recnty. for high speed miss,down shifting auto tranny produces same problem,high speed it runs fine,could this be a shift modual acting up,what do you guys think.thanks o2wgn
Old 05-01-2008, 10:54 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: engine miss or trany problem ?
Sounds like it could be an engine miss, that would likely be a less expensive fix than a tranny issue. If you have access to a scan tool that can display the Component Parameters, get into that mode and check for individual cylinder misfire counts. Even if the misfires are not high enough in counts to trigger the CEL, they may still be displayed if that's what's happening.
-Rod
Old 05-02-2008, 03:45 PM
thanks ROD FOR THE REPLY,i have to get my hands on a scan tool somhow.
Old 05-02-2008, 06:21 PM
shorod's Avatar
SHO No Mo
Many of the auto parts stores will scan codes at no charge, but I'm not sure how many of them have access to the component parameters or how many of the operators would know how to access them even if the tool is capable.
-Rod
Old 05-02-2008, 08:24 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
If you get a fuel pressure regulator code, replace the fuel pump. If you get a missfire code and it has new tune-up, it could be a coil or other issue.
