Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 05-01-2008, 01:08 PM
Jitterbug Jitterbug is offline
03' ES300 A/C Quit
03' ES300- The A/C quit a few days ago, the compressor will not come on. I've already evacuated the system and recharged the freon to the spec. amount.(It was only a little low) The A/C light on the dash flashes, the blower and all other functions on the control panel are working fine.
Any Ideas will be great.
Old 05-09-2008, 11:15 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 03' ES300 A/C Quit
First, check for a blown fuse. Next, there may be a faulty low- or high-pressure cutoff switch that is preventing the compressor from running. Low-pressure switch is usually just past the orifice tube near the condenser. High pressure switch is usually just after the compressor. Bypass one or both of the switches to find the culprit. And check the system pressures with a set of manifold gauges.
[edit]
Forgot to mention to check the a/c clutch wires for damage and the clutch coil for low resistance.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
