Old 04-30-2008, 10:17 PM
Raaz Raaz is offline
97 SOHC Oil Pressure Guage is showing High
Hi Everyone,
I have a 1997 SL (SOHC), and my oil pressure guage is almost near H.
The engine oil has always been changed on time, and the car does not burn or leak any oil.
When I am idle, the pressure guage does return to normal, but once I begin to drive it goes up to near H. I am not sure if this particular or any model for that matter have an Oil LED on the front dash.
Most of the search I have done has been more toward people reporting low oil pressure.
Can someone explain what's causing this? Other than the sender is faulty.
Thanks for any inputs!
Old 04-30-2008, 11:14 PM
new2mitsu new2mitsu is offline
Re: 97 SOHC Oil Pressure Guage is showing High
too much oil?
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 05-01-2008, 03:19 AM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Well, if you have checked your oil level and it is in check, my guess would be your gauge is faulty. The gauges in 3S's are known for being a POS.
Old 05-01-2008, 09:07 AM
Girly VR-4 Girly VR-4 is offline
we've had a few base models with very high oil pressure.
At least you know you won't be spinning bearings anytime soon from oil starvation
fyi, for some reason, SOHC's have a tendency to have higher oil pressure than the DOHC or TT models. No idea.
If it's always been like that, then there's no reason to start worrying about it now
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 05-01-2008, 11:41 AM
mistermoonpie mistermoonpie is offline
If I'm not mistaken, doesn't the 97 SL have DOHC?...Because MY 97 SL is a DOHC...Maybe you had an engine swap? In which case, perhaps some faulty engine work/wiring is to blame for the high oil pressure reading?
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 05-01-2008, 11:45 AM
you can't just swap in a SOHC. It's a little more complicated than that.
But he either has a 97 SL with a DOHC, or a 97 Base with a SOHC. or a mis-badged 97 base.
www.3swarehouse.com
Old 05-01-2008, 04:54 PM
AutostradaVR4 AutostradaVR4 is offline
indeed. the only 97 with a SOHC was the base model.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 05-01-2008, 05:58 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I wonder how close to the top it is. I had a Chrysler Sebring and it had a Mitsubishi 2.5L V6. When I got on the freeway it would get pretty close to the top.
Old 05-12-2008, 04:53 PM
This particular model is the base (SOHC).
Of course something new went wrong with the car, and I'm trying to figure out if it's the water pump or something else. I noticed there was liquid on the ground, and as I got under the car, I noticed it was the coolant. It was slowly dripping down right below the oil pan. When I cranked the engine, it started to drip even faster. I was trying to trace it down, but I can't see where it is exactly coming from, but it is definitely around the Water Pump/Timing belt area.. I am hoping I don't have a cracked Block.. I didn't see any coolant in the oil..
I was planning on taking it to my Mech. so he can make some recommendation. Unfortuently I don't have the time to tear the engine down, and figure it what's causing it..
Anyone wants to take a shot at this little Anomaly?
Old 05-12-2008, 06:24 PM
It takes a lot to crack an engine block, i would jump to such an extreme conclusion.
probably just a leak in the water pump gasket/seal. Any word on when the pump was last replaced/last 60k tune? how many miles are on her?
Formerly BlinkRA182
Old 05-12-2008, 08:14 PM
The previous owner did change all the belts (timing/accessories), water pump, and tenisoner pully. It was done around 134k.. the car now has 157k.. I bought it when it had 146k... it's been a good car, and I have enjoyed driving it.. When I took it in this evening, I didn't see it leak anymore.. which is very bizzare, since it was leaking fairly fast... so I guess I will hear back from the Mechanic in the AM.. and maybe he will find what the problem is...
I did check the oil fulid to make sure I didn't have head gasket cracked.. since I drove it about 10 miles to get to the shop..
Thanks for your input
Old 05-13-2008, 06:14 PM
Well, I got some news from the Mech. and it's not looking good..
He thinks it's the freeze Plugs or the head Gaskets having a small leak.. he said he really didn't want to mess with it, since these types of engines are hard to work on, without charging an arm and a leg..
So, I guess I will take to the dealership, and see if they can isolate the problem.
I did notice, once the engine is hot, it does not leak... so the expansion of the metal does help some...
Anybody know where the location of the freeze plugs are by any chance, or have a diagram of it?
If I end up doing the work myself, I will have to buy one of those Real "Shop" manuals.
